Question about JVC Car Audio & Video
I have a jvc kd/a735bt/ kd-r730bt CD reciever in my car. I installed subwoofers and an amp but cannot figure out how to activate the system through this receiver...also how does the wiring go in the rear of the reciever??? Please help!!!!!!!
Noggin
  • 944 Answers
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Posted on Mar 17, 2007
  • 7 Answers
SOURCE: DOESN'T WORK AFTER INSTALLING A NEW CAR BATTERY
did you check the fuse on the back of the radio. it should be a small maxi fuse that might be rated any where from 5 to 20 amps. most of the time it might be helpful to unplug the radio harness and re plug it after 1 minute.
Posted on May 28, 2008
tech48
  • 624 Answers
SOURCE: on a jvc kd-g632 cd
The turn on voltage that the amp needs comes from the radio wiring harness and it is the blue wire that is in between the red and the white wires on most JVC radios.
Hope this helps and a rating of "FixYa!" would be appreciated for this free information.
Let me know if you need any more help.
Dave
Posted on Jul 21, 2008
  • 7 Answers
SOURCE: JVC KD-G396 wont Play any cd or mp3 PLEASE HELP
take it back
Posted on Dec 14, 2008
SOURCE: how to set the displayed time in JVC KD-G110 car music system?
i couldn't able to set the time in my radio if possible can u please help me Thank u
Posted on Apr 06, 2009
Installing a KD-R530 in a 1995 volvo 940
Your best bet is to go to a location that sells install kits and purchase one. Otherwise you have to figure out what lines match up to what lines on your own. One bad connection and you can fry your reciever.
Jul 03, 2012 | JVC KD-R530 CD receiver
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
Jvc kd-g340 rear speakers not working. I recently bought the car with this unit installed. I noticed that there is a l/r cable, power, ground in the trunk which means there was probably a subwoofer...
check the wires in the back of the stereo if not then make sure the back speakers are not hooked up to a internal amp and if it is make sure that it is not blown
Mar 31, 2010 | JVC KD-G340 Car CD/ MP3 Player
Need user manual for JVC KD G 395
free manuals are available on elitezoom.com they should have 1
May 10, 2009 | Car Audio & Video
Settings
hola, nesesito ayuda para poner la hora a mi estereo jvc kd-g320 ya le busque por todos lados y no le encuentro.. si alguien puede ayudarme, se lo agradecere... gracias.
Feb 04, 2008 | JVC KD-G320 CD Player
JVC KD-G420 in 2000 Toyota Tocoma
today's in-dash cd players are a 2 part mounting system. One part is the carrier chassis that is hard mounted to the dash. Then the cd player slides into part 1 and latches. To remove player from part 1, insert 2 long and narrow metal tools along each side to un-latch the player. The tools come with a new unit. To make these, try making them out of 1/16 inch thick metal and trimming to following dimensions: 6 inches long by 1/2 inch wide and at one end, narrow down to about 1/8 inch about 1 inch from the end. deburr all edges. This 2 part system is designed for anti-theft defense.
Aug 26, 2007 | JVC KD-G420 CD Player
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
Installing sirius reciever manual
what kind of sirius reciever, JVC, Kenwood, Pioneer? is it ran through a FM modulator?
basiclly i need more info on the sirius unit
Thx,
Don
Feb 27, 2007 | JVC Sirius KD-LH300 CD Player
Car Audio & Video Logo
184 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
