Question about Philips 50PL9126D/37B 50" DLP TV
Where is the power board for a phillips 50inch model #50pl9126d/37
Replaced lamp an lamp comes on for a few seconds when plugged in but flashes off. Questioning if this could the power board or bad lamp?
    Top Expert:
  • Philips Master
  • 74,383 Answers
Hello
As far as the lamp stays lit for a few seconds, all other voltages comes to the lamp and inverter board are OK. If the lamp has reached its life time, this type of fault can occur.
Posted on Feb 16, 2012
SOURCE: 50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Posted on Mar 23, 2009
  • 14 Answers
SOURCE: my phillips tv picture screen keeps going out
U MIGHT HAVE A PROBLEM IN THE POWER SUPPLY OR HAVE CONVERGENCE PROBLEM IF YOU HAVE A LITTLE KNOWLEDGE ABOUT IT CHECK UR PRIMARY THEN YOUR SECONDARY IN POWER SUPPLY WITH DIGITAL METER, IF UR READINGS LOOK GOOD THEN CHANGE THE STK'S THE ONES THAT CONTROL THE CONVERGENCE FROM PAST EXPERIENCES STK'S ARE THE ONES THAT MOST LIKELY GO OUT. IF YOU DONT KNOW HOW TO DO THESE THINGS CALL A TECH.
Posted on Jan 29, 2010
SOURCE: need a lamp in my philips 50PL9126D/37 TV
Unplug unit and remove lower back panel should be 2 screws on each side and a few across the middle. Pull panel back and you should see a black box with metal folding handle. Remove the two left screws and pull out.
Posted on Apr 28, 2010
SOURCE: I have a Phillips 50pl9126d/37
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Posted on May 17, 2010
SOURCE: need to change lamp in philips hdtv model #
how do you get back panel off model 50PL9126D/37 philips tv ???
Posted on Jul 06, 2010
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
I was watching tv and i heard a loud pop.then my picture went out but i had sound.red light in the front comes on model number is 50pl9126d/37
If it is a lamp led light in the front panel, this is an indication that the lamp is not working. Pop sound was came from the electrolytic capacitor most probably in the ballast board that's why the lamp is dead. When the ballast board gone to malfunction, no high voltage will feed to the lamp resulting to that kind of symptoms.
Faulty capacitor has a physical indication of fault like bulged/dome at the top. Check the ballast board and inspect the capacitor. If you found it faulty, I would advice you to replaced the entire ballast board if you can't troubleshoot it yourself. Click this LINK for the replacement.
Also, check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Oct 08, 2009 | Philips Televison & Video
Power light flashes but tv does not come on
when you plug in the tv the relay start clicking and the blue lite on front panel at the same time
Dec 26, 2008 | Philips 50PL9126D/37B 50" DLP TV
Philips TV, Model # 50PL9126D/37
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Sep 23, 2007 | Televison & Video
Philips 50PL9126D/37B 50" DLP TV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
