Question about HP Pavilion dv9500 dv9600 and dv9700 FF Athlon Motherboard - 450799-001
Dv9823cl wont boot. Powers on then shuts off. Tried with and without bat. Tried holding f10/f12 will powering in. Please help is this the video board problem??
  • HP Master
  • 27,725 Answers
test all leads that attach to your hard drive including electrical extensions IDE/SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 17, 2012
HOW TO ENTER SAFE MODE
hold down F8 when it powers up. May need to remove battery and power cord. New windows 8 and probably windows 10 do not fully power down usually you have to hold shift key when shutting down windows from operating system. So it may not go into safe mode without it being shut down fully.
Nov 22, 2015 | Acer Computers & Internet
How to change toshiba 2000 booupt priority
try holding f2 f10 or f12 this will require up to 3 reboots to figre which one but just hold down one of thse during startup
May 20, 2012 | Toshiba Portege 2000 Laptop AC Power...
How do I instal a fresh copy of XP on the 350 21g16i as the newtbook just beeps when I connect up external cd reader & USB....HELP....
Did you try to boot from External drive or USB? have u tried to press F12 on your unit before the start up?
Steps:
1.) Power on your computer
2.)Press F12 or F10 to go boot device
3.)Select what drive do you want to boot .
4.)Install Windows XP.
Hope it helps.
Sep 13, 2011 | Computers & Internet
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
My computer won't boot on cd, i cant repair it with my XP CD, any help would be much appreciated. my processor is p4s533-mx
During the boot press the F12 key to select your boot option and choose your CD drive. Depending on your system it could be the F10 key, it should display the option during the post.
Sep 01, 2009 | ASUS P4S533-MX Motherboard
Toshiba laptop l305d won't reboot to factory default
I never heard of holding the 0 key, but have you tried hitting F10 or F12? Normally when you first boot the computer you will see down in the bottom of the screen or on the top corner to press a certain key for system recovery and a certain key for entering setup, etc. It will probably be one of the function keys like F10 or F12, but I believe I have used F2 on a few. Easiest way is to check what your computer says when you first boot it.
Jun 17, 2009 | Computers & Internet
Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Mar 06, 2008 | Computers & Internet
HP Pavilion dv9500 dv9600 and dv9700 FF Athlon Motherboard - 450799-001 Logo
117 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
