Question about Whirlpool Washing Machines
Whirlpool estate ETW4400SQ0 keeps filling, overflows.
Water runs during all cycles, tub overflows.
Washer_tech
  • 164 Answers
SOURCE: Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
Lumpy816
  • 246 Answers
SOURCE: kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Posted on Jun 17, 2008
  • 116 Answers
SOURCE: my washer will not stop filling with water.
If it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. This is inside of the machine and the lower cabinet will have to be opened to see it.
There should be two screws along the lower front edge of the washer cabinet. Remove these and the front of the cabinet will lift out towards you at a 45 degree angle an then unlatch. Unplug from power before opening the cabinet.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out.
Posted on Jul 28, 2008
  • 32 Answers
SOURCE: Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Posted on Apr 22, 2009
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Dec 26, 2012 | Estate Washing Machines
M/N ETW4400SQ0 The small pin, 2" with cotter pin hole in the end, underneath the machine, with a opaque capture shield has come loose from the spring it holds? In turn during spin cycle the...
Hello Mike
Those cotter pins with the shield over them were part of the shipping braces from when it left the factory and they do have no bearing on the suspension system.
What most likely thats causing it to vibrate so badly are the cresent shaped plastic peices that fit between the plates under the outer tub,Their is 2 types of those on the washer one fits under the bottom plate and one fits on the top of the bottom plate andin between the upper and lower plate. They are impregnated with teflon and have worn out so instead of the plates sliding free the are grinding against each other
Those parts are called suspension pads,the part number for them is 285744 &285219 they can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
This link shows where they are they are item numbers 13&15
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Washer-Parts/Model-ETW4400SQ0/3191/0153200/W0607071/00005?blt=06&prst=0&shdMod=ETW4400SQ0
GENE
Sep 24, 2011 | Whirlpool Washing Machines
Washer keep filling with water and will not kick over to next cycle mode for wash or spinning cycle on cold water?
Hello, Assuming the washer doesn't keep filling to the point it is overflowing the tub, it sounds like you have a bad lid switch. If it is overflowing then you may need a pressure switch or more likely the pressure switch tube (surgical tube) is just clogged where it connects to the outer tub. You can go to - http://www.searspartsdirect.com/partsdirect/index.action - Type in your model number then select model search. You can get part breakdown and buy parts for most brands. Good Luck.
Mar 12, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Estate washer ETW4400SQ0 water runs, but does not fill completely
The water inlet valve sticks open at times because of sediment in the water. Disconnect the water and flush it out and clean the screen filter where it connects to the inlet valve. It's probablly just the cold water side sticking.
Jul 08, 2009 | Washing Machines
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
