Question about Garden
1641 pto wont stay engaged
When you release toggle pto shuts off
wadembly
  • 513 Answers
SOURCE: pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Posted on Jun 05, 2009
moretons
  • 155 Answers
SOURCE: pto won't stay ingaged on 1641 tractor 1993 year with briggs eng.
the clutch may need adjusting the clearence should be 10 thou you measure with a feeler gauge through the three holes on the side and adjust with the three nuts
Posted on Jul 27, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
wireguy212
  • 1627 Answers
SOURCE: When I engage the PTO clutch, the amp light comes
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Posted on Nov 07, 2009
  • 198 Answers
SOURCE: Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
Posted on May 12, 2010
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Everride warrior pto wont engage
most likely the engagment switch, usually yellow knob. the seat safety shuts the mower off so if the mower is still running it is not the safety under the seat.
May 05, 2013 | Garden
Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Jun 03, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
Nov 07, 2009 | Garden
Pto won't stay ingaged on 1641 tractor 1993 year with briggs eng.
Jun 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Husqvarna Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
