Question about Mitsubishi VS-4544 45" TV
Mitsubishi vs-4544 need parts
Where can I find the seals for the crt's and the fluid this 1996 TV. I havent had much luck so far.
Wanual
Posted on Feb 24, 2009
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
Need Horiz button help on Mitsubishi 45" TV...easy fix?
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Oct 20, 2009 | Mitsubishi VS-4544 45" TV
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Need to find where the fan is located?
The VS4544 doesnt have a fan as thats a CRT based rear projection TV
Apr 26, 2009 | Televison & Video
Power problems
 high voltage regulation problem. need tech service.
Nov 23, 2008 | Mitsubishi VS-4544 45" TV
TV wont power up
lose connection is a common problem of tv, try to resolder but be careful of short circuit ,
Oct 14, 2008 | Mitsubishi VS-4544 45" TV
Green light blinks 3 times
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Aug 18, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi projection tv
Good Day;
Aug 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitusbushi VS-4544 Horizontal lines then looses picture.
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Dan
Jul 14, 2008 | Mitsubishi VS-4544 45" TV
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
Televison & Video Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
