Question about Canon imageRUNNER C3200 Copier
010b jam code on 11x17 duplex - Canon imageRUNNER C3200 Copier
  • Sabrina Sikora Feb 16, 2012
    I have previously replaced the fusing unit, vertical path assy, vertical path door, duplex driver board. It will jam after about 75 duplex copies and the jammed copy will be wavy and being fed back into the fuser even tho printed on both sides.
Missfeed 010B canon ir7105
Your fuser assembly is not rotating, the drive gear is broken, the bushings inside the bearing is broken or worn out.worst case fuser drive motor. those fusers are rated at 500k. Take the front cover of the fuser assembly off and inspect that area for the problem. look for broken gear.
May 22, 2014 | Canon Office Equipment & Supplies
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
IR5570 jamming from paper deck #2 but having a 0201 jam code what possible solutions ....changed the feed sep and pu tires and also replaced paper deck #2 registration rollers going into the duplex...
Check the duplex motor that feeds the reg roller shaft - in the front of the duplex unit. I found one that was loose, when I opened the front duplex cover and moved the motor, the screw fell out! The motor gear and drive gear were not touching. Good luck
Jan 27, 2010 | Canon Office Equipment & Supplies
Duplex jam 0 - check inside
hey just open the back door of your printer remove the jammed papper...den resart your printer n then print...Robert
Jan 05, 2010 | Dell 1815dn All-In-One Laser Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
Canon imageRUNNER C3200 Copier Logo
old marine
old marine
