Question about Philips Magnavox 42MF521D/37 Television
Phillips tv has no sound - Philips Magnavox 42MF521D/37 Television
  • Philips Master
  • 8,617 Answers
Replace the Main board audio is produced and controled on that board
Posted on Feb 16, 2012
Phillips 409fl7505d/f7
I once had a problem with a Phillips tv.It was less than one year old and one day ,all of a suddenm a black screen came up.I elarned it was called the "black screen of death" and that other people had gone through the same thing.Someone online had actually written to Phillips and they had gotten a new TV form them,so I tried the same thing and amazingly,Phillips gave us a new TV and came and took the old one.The enw worked fine. So you may have a lemon on your hands.Unfortunately, I do not have the letter I sent to them but the replacement they sent me was part of their "Rapid Replacement" program.This wa sin 2008 so I'm not sure if they still ahve it but it may be worth a try.
Apr 09, 2013 | Philips 40PFL3705D 40 in LCD TV
When you turn tv on it just makes a clicking sound its a phillips model 60pp920217f
If the front panel indicator lights, you are getting power to your TV. The symptom you describe suggests the power supply has failed
Jan 04, 2013 | Philips TV Tuner Video Capture PCI Card -...
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Aug 07, 2009 | Philips 52PFL7422D/37 TV
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips 32" LCD TV, Sound through TV speakers has a buzzing noise which is steadily getting more aNNOYING AND LOUDER.
We are having the "buzz" problem with our new 42' Phillips LCD too.
We do not have a sound system yet...but have read they have the same problem, so I won't assume when I get a sound system it will go away. What I did do for now...and it helped..
Go to the SOUND portion of TV menu
Choose EQUALIZER
Turn down the two FAR RIGHT columns, they are the treble. It helped us.
Aug 26, 2008 | Televison & Video
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Need help
i have a Phillips Tv 37 in model 36pt71b129 and when i turn it on it has a very loud snowy sound coming from the speakers, the
SAP is unavailable so i cant adjust it. What is the problem?
Nov 17, 2007 | Philips TV Tuner Video Capture PCI Card -...
Philips Magnavox 42MF521D/37 Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
