Question about Home Security
I am trying to program 2 remote controlls to a chamberlain roller door. model No. MTL 051K. the electronic controller is a Grifco eDrive model No. ML4051.
I HAVE NO MANUALS. ONLY THE PROGRAM GUIDE FOR A GRIFCO MK3
mohammed387
  • 1952 Answers
SOURCE: Programing limits on a Grifco MK3 Garage door Operator
It has the "Protector System" (safety sensors). chec the sensor indicator light on the receivinng eye the green light had a slight flicker.cleaned both the sending eye and receiving eye lens of dust and cob webs, then realigned the receiving sensor for a steady green indicator light. then check the door function it now works fine.over time, temperature, and viberation the sensors become dirty and get out of alignment, as no one had tampered with the sensor alignment prior to this. Hope this works for you.
Posted on Nov 21, 2008
  • 1550 Answers
You can get manual from the link below
Garage door
  • 188 Answers
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: I have a chamberlain 953CD New will it work for a Lift-master ?
You may need a C943 as the + can make the siginal different.[Chambelain or Merlin]
Posted on Apr 15, 2010
swolfinor
  • 504 Answers
SOURCE: how to program garage opener
SORRY,
Chamberlain key pads won't work with a genie receiver.
You will need to echange it for a Genie brand.
Also be sure what frequency your Genie is - They have changed the frequency a couple of years ago.
Posted on Jun 30, 2010
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
We tried to program an old chamberlain remote to our new craftsman opener through the door console--now the door console does not work--we reprogrammed the keyless entry and car remotes with the main unit...
The door control does not require programming. Make sure one of the wires hasn't come loose and also try loosening the top screw on the door control. If it is too tight it can cause a problem.
Mar 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
HAVE SEARS/CHAMBERLAIN "91"MODEL 53615SR AND NEIGHBORS OPENER KEEPS OPENING OUR GARAGE DOOR BUT OUR OPENERS WONT OPEN HIS
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Dec 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have the same problem.The garage door opens or closes on its self after setting up the new remote chamberlain. i foun out every time my nabour closes his garage door mine opens.
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
23 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
