Stop others using my computer
I am informed when logging off that others are logging on to this computer
shutting down my lose information
    Genius:
  • 1,913 Answers
I think your remtore desktop is enablee.
go to my computer properties.then go to Remote then disable the check box.
Posted on Oct 25, 2008
Laptop gives error.
To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options:Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 How to use the Userdump.exe tool to create a dump file
    Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors
Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Notes
  • Choosing the Last Known Good Configuration startup option provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. However, it does not solve problems that are caused by corrupted or missing drivers or files.
  • When you choose the Last Known Good Configuration option, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • I hope this info from Microsoft helps.
Dec 09, 2013 | Computers & Internet
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Dec 23, 2010 | Computers & Internet
What are the implications of using force quit on a mac 10.6?I want a quick way to shut down my mac?by using force quit does the hard drive shut down properly?
Force quit usually shuts down an app that is not responding and not your Mac. Should be no implications on the Mac itself - is the equivalent of using task manager to end a program on Windows.
If your Mac won't shut down, just hold the power button in for about 7 seconds. Should not cause any damage other than you losing any unsaved information.
Hope that helps, pls rate the solution
Nov 22, 2010 | Computers & Internet
I cannot shutdown my Windows 7 computer. It never shuts off so when I have to restart for an update, it never shuts down completely and just comes back up to the desktop.
Check if a particular program is slowing the machine when you switch on or shut down, e.g. an anti virus program.
Go to Control Panel > All Control Panel Items > Performance Information and Tools > Advanced Tools (in the left pane). On this screen the problem is sometimes shown. If not, click View Performance Details in Event Log (Event Viewer). Events in the 100 series are boot events and I believe those in the 200 series are shut down events. These can be followed up by double-clicking them, then clicking Event Log Online at the bottom.
Hope this initial information helps. Let me know for further instructions.
Thanks.
-TA
Oct 10, 2010 | Computers & Internet
I can't shut down my PC,It restarts again!
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Screen doubled, now cannot log in, cannot stop iphone
It may be too late, but if you try double tapping with three fingers then dragging up or down, this might change the zoom of your screen, showing the rest of the screen for you. Then go to Settings>General>Accesibility>Zoom and turn it Off, if it's not already. Also, restoring your iPhone will keep all your media, Contacts, Documents, Calendar etc, but you will lose your preferences and settings and probably your network information also. Hope this helps...
Sep 19, 2009 | Apple iPhone 3GS Black (16 GB)
Not shutting down
sounds like that when you did a restore one of the files did not load correctly try using your repair disk and that should fix it
Feb 10, 2009 | Medion M3 Composer 5200 PC Desktop
WHAT IS THE RESET BUTTON ON THE BOTTOM SIDE OF MY COMPAQ PRESARIO 2500 SPECIFICLY DO. IN OTHER WORDS IF I PUSH IT WILL I LOSE ALL MY STORED INFORMATION ON THE DRIVE?
This is straight from the manual:
Occasionally, Windows or the notebook might stop responding, so that you cannot turn the notebook off. If this happens, try the following in the order listed. Press the power button to restart.
• If possible, shut down Windows: press ctrl+alt+del, and then select Shut Down > Restart.
If the system will not allow a software shutdown, press and hold down the power button until the display shuts down (about 4 seconds) and then release the power button. Press the power button again to restart.
• Use a ballpoint pen or a straightened paper clip to press the reset button on the bottom of the notebook.
In other words: You will not loose any saved data if you reboot your laptop this way. All unstored information (open documents etc.) might be lost though.
Dec 20, 2008 | Computers & Internet
Can't log in - TouchPad does not work
You you cannot navigate using Touchpad you can use "tab" key. if doesnt work also shut the computer by holding the power button about 5 seconds and restart the computer. If issue persist please post your question with model information of the computer, Operating system etc.
Good Luck
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
