Question about Rokinon DZ1000 Digital Camera
The touch screen on my digital camera has disappeared. How do I retrieve it?
Displays no touchscreen icon. Camera beeps when turned on then cuts off after 6 beeps or so.
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Left side of touchscreen does not work as expected
You think it could be possible the beep will be heard where ever you touch the screen, because the sensor for that is different from the matrix that is scanning where you touch?
In my opinion, the touch screen is defect, and it takes a certified repair shop to solve the problem. Perhaps even the complete screen has to be replaced. before you agree with any repair, ask what it will cost and check what a new camera will cost.
Feb 20, 2014 | Sony Cameras
Cuts off shortly after turning it on
Sounds like you have a short some place, and it needs to be replaced.
Dec 25, 2012 | Hamilton Beach 33966 6-Quart Slow Cooker
My Pentax Optio M20 has an upright leaf image when turned on, with or without memory card installed. Lens image and other displays are barely visible in the background. I can't get rid of foreground leaf...
Sounds like you're in "macro" mode. There should be a button on the camera with the leaf icon. If you push it repeatedly, watch the screen for the leaf icon to disappear.
Mar 28, 2010 | Cameras
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
Rokinon DZ1000 Digital Camera Logo
32 people viewed this question
Top Rokinon Cameras Experts
Are you a Rokinon Camera Expert? Answer questions, earn points and help others
