Question about Sony DCR Video Cameras
Sony DVD91E Door Jam
Hi All, Great site just signed up! I'm looking for some help not too sure if you can but here it goes. My friends camcorder (DVD91E) got spashed with sea water but has now recovered and appears to be working but the door won't open. I also have the same camera and have had a look at the mechanism which consists of two overlap hooks that lock the door but these are concealed with the door shut so I can not access them to 'persuade' them to open. When the door button is pressed the camera make a series of beeps which is normal but the actual mechanical action does not kick in to release the 'hooks'. Can anyone give me any ideas of what to try to get the door open? Many Thanks Ryan
SOURCE: Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Posted on Feb 19, 2007
  • 72 Answers
SOURCE: Door lock stuck
If the mechanism is jammed, you might have to remove or loosen the entire front panel to reach back to the back side of the lock and work on it.
Posted on Feb 25, 2007
  • 169 Answers
SOURCE: sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Posted on Aug 10, 2007
SOURCE: my camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Posted on Apr 26, 2009
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
I need a manual for SONY DCR-TRV Digital 8 Digital camera
Hi great camera you got my friend, nothing to beat the 8mm if you are planning making good movies that last.
You can get your booklet replaced at Sony agents like you will see on net, type Sony Support centre, then look for tel num in your location.
Take care,
David Suffolk
Jun 25, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
The swing out screen is messed up and it happend with my old camera also
Messed up??? what with Jam? toffy? Candy Floss? or broken by being heavy fisted? not sure but if it is the latter then you are going to find filming is quite a costly hobby as repairs like this you are looking at lots of money my friend, maybe you should stick to filming with a less plastic type camera like the Sony Hi 8 digital type, made for men by men.
Jun 21, 2010 | Sony Handycam DCR-SR82 Camcorder
Discs will not play back on dvd
What DVD's are you using +R/RW -R/RW some formats may not work especially on non-branded media some DVD players wont even play CD-R but will play some CD-RW of the correct brand.
I suggest that you try your finalized DVD in your PC then create an image using ImageBurn then burn the image onto a branded media and try again. Most firmware on DVD burners are very forgiving and will support a wider range of manufacturers and formats.
Hope this helps, you might want to look on your DVD players website for updated firmware you will need a blank CD and create a update disc using your computer.
Oct 18, 2009 | Sony DCR-DVD91E DVD Camcorder
Power windows and locks quit. fuses are good no short in wires
Look in the door jam. my friends truck had the same problem the wire that goes through the rubber hose lookin thing in the door jam broke and then we fixed it and they worked.
Apr 22, 2009 | 1989 Ford F 150
Shutter will not open
Its problem of bad ccd imager in DCR-DVD91E camcorder and this part needs to be replaced.
Sony will repair this camera free of cost as per announced scheme.
Click Sony CCD Support for details, how to get free repair. (check camcorder model in model list)
Dec 23, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony dcr-dvd602e,no software in computer
try this sir it will be helpful for you and your camcorder.
and heres the manual
just download it and be sure you have a pdf reader for this to view what contains in it.
hope that helps!
Oct 07, 2008 | Sony Handycam DCR-TRV140E Digital...
Cannot view dvd made from sony handycam
    • hi sir,
    • here is the link to download codec software
      THANK,YOU don't forget to rate it..
Sep 09, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Hi Mountainsoul I have found the manual for you to download at Sony's site HERE
Please rate my answer ,happy recording.
Aug 17, 2008 | Sony Handycam DCR-DVD103 DVD Camcorder
Video Cameras Logo
59 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
