How to connect a sub to technics sa-gx100 receiver
5 Suggested Answers
tech240
  • 169 Answers
SOURCE: probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Posted on Apr 25, 2008
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
SOURCE: I need a code for my Technics receiver SA-GX100 to program remote
technics codes:4007, 4008, 4026, 4045, 4073,
sony cd codes: 5001,5002,5099,5100,5101
sony vcr: 1001; 1002; 1003; 1004; 1005
good luck and vote for if it works
Posted on Aug 30, 2009
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
Older technics SA-GX100 sometimes left or right speaker will not work until volumes is cranked up
buy some turner cleaner or electrical contact cleaner(radio shack) with the power off take the volume knob off spray into the area where the knob goes(the little metal post) turn the post back and forth with your fingers or needel nose plyers several times (over time dust and dirt build up makes a bad connection) you may have to do this a couple of times dont worry this stuff drys realy fast this should do the trick
Sep 06, 2014 | Panasonic Technics Sa Gx100 Amplifier...
Where is the aerial input located on this item
Look for 2 small shiny metal screws on back, fm aerial is usually a T wire with couple forks which go under the shiny metal screws.
Nov 16, 2013 | Panasonic Technics Sa Gx100 Amplifier...
I have an old Technics SA-GX300 receiver that works fine except that the screen indicates that muting is on (still produces volume but at much lower levels). I lost the remote to the receiver. Is there...
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Jul 08, 2011 | Technics SA-DX850 Receiver
My Technics SA-GX100 Reciever worked for a minute, but when i set it up with all the speakers and attachments, it says "muting". i dont have a remote, so how do i UNMUTE it?
According to my Technics SA-R210 manual to UNMUTE without the remote....do the following......PRESS BOTH THE VOL UP & DOWN CONTROLS & THE LOUDNESS SWITCH ON THE UNIT AT THE SAME TIME......Not sure it will work for your model but that is what it shows for The Technics SA-R210 model, so it should be pretty much the same
Sep 04, 2010 | Technics SA-AX720 Receiver
Connecting sub speaker to technics sa dx930
Yes, if it only has speaker-level inputs it would require an amplifier to properly drive it. Name the sub and maybe we can answer the second question.
Mar 28, 2010 | Technics SA-DX930 Receiver
Aug 02, 2009 | Televison & Video
Apr 06, 2009 | Technics SA-AX720 Receiver
Remote control code
You need to let us know the make and exact model number of the universal remote. All universal remotes do not use the same codes. We'll try to help you control your technics sa-gx100 upon your reply.
Sep 29, 2007 | Audio Players & Recorders
29 people viewed this question
 Grubhead
Grubhead
