Question about SanDisk Sansa m230 MP3 Player
My Sandisk m230 Won't Work??
Everything works Right I've tried the Fm radio and the Voice recorder and they work but when I put the Usb port into the slot Nothing Happens with the Mp3 or My computer. I don't know What I'm doing wrong.
  • 8,596 Answers
MTP vs MSC mod eis the key
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
I am a News Director for a radio station. I have
You could have a virus but, I've noticed a lot lately of having to re-install about everything, software and drivers. The "bad file format", tells me the software that handles those types of files isn't operating right or on the computer, possibly. The USB device that you have could had the USB port conflict with an update or some other software. My Ti 89 won't even connect until one time, I put it into a USB port that I never use and it started working correctly. My video card, I make operate with out updates because, I can only make it work with an older version. You really have to keep up on this stuff or you start having problems. Then when you can't seem to keep up with it, you know you might have a virus. Hope this helps.
Sep 28, 2009 | Audio Players & Recorders
Fm radio and recorder modes
On this model, the Power button and the Menu buton are the same key - press the Menu button to go to the main menu, and it will display FM and Voice options.
Here is a link to the user manual:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa c200 MP3 Player
Sansa mp3 player not detected by system
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
CL23
Feb 15, 2008 | Computers & Internet
Voice recordings to cd
Look in the RECORD folder for your recorded .WAV files. These files may or may not work with Windows Media Player, which can generally be used to burn music files to a CD in the CD audio (CDDA) format or .WMA music data format. Conversion of the wave files into other formats, such as .MP3 is especially difficult since many programs don't recognize the headerless format that Sansa uses for its recorded .WAV files. I had to use JetAudio to convert them.
Oct 18, 2007 | SanDisk Sansa m230 MP3 Player
Deleting Voice Recordings off my Sandisk m230 512 mb
Yeah... Go to "My Computer," and select the player by right clicking and then hitting explore. You then need to hunt around in those folders till you find your recordings and then just highlight them and hit delete. If you can't find them, try starting over, then after you "explore," go to tools-->folder options-->view--> then turn on "view hidden folders" Hope this helps!
Jul 27, 2007 | SanDisk Sansa e250 MP3 Player
M230 big problem
Remove the battery from the player. Enable the hold switch and connect the player to the computer. Right-click on My Computer and choose Manage. Click on disk management if the player is listed there right click it and choose format. This will erase all the songs on the player. If the player is not listed there try another usb port. If all else fails try calling sandisk to see if there are other steps they could provide.
Sep 25, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
126 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
