Question about Dryers
I want to change light bulb on a nutone bath vent light model 8662nl
Round newtone light and vent for bathroom
4 Suggested Answers
  • 377 Answers
SOURCE: How do I change the light bulb and/or night light
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Posted on Sep 19, 2010
bargainbin2
  • 123 Answers
SOURCE: Older Nutone bath- fan/light/heater Model
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Posted on Aug 29, 2009
sawdust46694
  • 398 Answers
SOURCE: NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Posted on Nov 03, 2009
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
FAN DOES NOT GO ON AND CAN THE FAN MOTOR JUST BE CHANGED WITHOUT REPLACING THE COMPLETE UNIT ??
Yes and maybe.
If you open unit, usually fan motor is plugged in, and motor is removable with bolts.
The problem is finding new fan that fits same housing without spot-welding and drilling.
I did google image search for "replacement vent fan motors" and results show choices.
For example Nutone:
http://nutoneproducts.typepad.com/nutone-products/nutone-bath-fans/page/2/
If you can locate same brand vent at local box store, you can use parts from new one to repair old one without project of replacing fan housing.
20 years ago, motors went to electric repair shop and they rewound the motor.
But today, motors are landfilled or shipped overseas for recycling.
All costs are energy, and right now, cost of re-wind is more than buying new motor, or new vent.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Panasonic WhisperCeiling Bathroom Fan...
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I think that the plastic round will pop out of the center--held in by tabs?
Mar 02, 2009 | Broan-NuTone QT100L Fan
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Dryers Logo
998 people viewed this question
Top Dryers Experts
