Question about Dishwashers
No power to maytag dishwasher model mdb5601awb
Replaced control board, but did not solve the problem.
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 1073 Answers
SOURCE: I have a Maytag dishwasher
you have to power the unit back up and then holld the lock in for three seconds, if ths does not reset it then the console not the control bord needs to be replaced it comes with a new touch pad
Posted on Apr 10, 2008
  • 338 Answers
SOURCE: no power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Posted on Nov 29, 2008
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 3741 Answers
SOURCE: I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Posted on Aug 28, 2009
Testimonial: "Thank you so much for the quick and informative answer. It is greatly appreciated. "
My Maytag dishwasher cycles seem to be confused. it beeps throughout, runs all day or won't turn on at all
control board issue probably, not made to last anymore
press the helpful button and follow me on Fixya for more good tips
Jan 27, 2016 | Maytag Dishwashers
My maytag dishwasher model MDB7749SAM stopped working about three days ago. The start/resume button flashes continuously and won't turn off. I flipped the breaker switch but nothing reset. The cancel...
Most likely moisture has affected the switches in the panel or the controller is faulty.
Refer assembly shown in the link below. Open the panel and locate the ribbon cable. Carefully take it out and with a hair dryer lightly dry up the parts. Put everything back and turn power back on. If no difference still then you may have to replace the control board.
MAYTAG Undercounter Dishwasher Control panel and latch Parts Model...
Aug 01, 2014 | Dishwashers
Can I repair the control panel on my maytag dishwasher myself? Is there more than one control panel?
Remove the screws and take a look at the control panel board. Everything is modular these days so the control panel, power supply board etc should all be plug and play. Look for a part number on the board and source a new one online. It might be around $100 though so check the main board for a fuse. It might be soldered into the circuitry but can still be replaced if your inclined to do so. Test it with a voltmeter to see if it is blown or current passes through it.
Jul 15, 2014 | Maytag Dishwashers
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
Led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
Aug 17, 2009 | Maytag MDB9600A Jetclean II Built-in...
Model mdb7601awb diswasher . Nothing works , no buttons torn on or work when pushed, no action. 1.Have checked power to unit and is ok 2.checked door switches (2) and both work properly. 3. no visual...
I have had the board replaced 5 times and the entire dishwasher replaced once. It was necessary to go to the state attorney general to get Maytag to extend the warranty. Just called the service center for the sixth time, after this the warranty will be gone and will replace with something well built.
May 12, 2009 | Maytag 24 in. MDB7601AWS Stainless Steel...
Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Jul 01, 2008 | Maytag 24 in. MDB5600A Jetclean II...
MAYTAG QUIET SERIES 300 DISHWASHER MODEL MDB7600AWW
Order and replace the front panel only - not the control card. This will resolve the problem.
May 07, 2008 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
