Lite On eHAU424 External Drive
When I open Nero 9 smart start system. It doesn't recognize my dvd drive. So I went into windows explore and when to "My Computer" and the dvd drive doesn't show up there either. All it shows is my C:/ , Q:/ (backup drive), and the E:/ (Cd Burner). Why isn't my computer recognizing that my external drive is a dvd burner also?
CoachTim
  • 202 Answers
SOURCE: My external dvd burner is not showing up as a valid dvd drive
I don't think the burner is compatable with Mac. http://www.mdmm.com/products.php?categoryid=2 Here is the site. Check your model here. I only found Windows compatable. Good Luck, Tim p.s. someone out there must have some hacked driver.
Posted on Feb 08, 2007
XboxModifier
  • 123 Answers
SOURCE: burner not recognized
have you tried another burning application, If it works as a normal dvd/cd drive then I cant see any problems with IDE cable config as stated by Bear001, Does Nero 7 reconise the dvd burner, you could look on neros website to see if this is an issue or maybe use version 6, I have had no probs with this version, let me know how you get on and good luck!
Posted on Feb 15, 2008
  • 43 Answers
SOURCE: My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Posted on Feb 17, 2008
  • 262 Answers
SOURCE: i o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
Posted on Aug 26, 2008
ginko
  • 19396 Answers
SOURCE: nero cd burner software
Here you find all the downloads available for Nero.
Don't forget to rate the solution.
thanks
Posted on Sep 01, 2008
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
No how i can get nero smart for my compaq 610 asus dvd writer i m using window7
Nero 9 is a free burning utility available through the Nero software company that allows users to burn audio and video files to blank CDs and DVDs.
Just search 'Nero 9 download' on google.
Aug 20, 2011 | Compaq (158165-001) DVD Drive
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
My LiteOn iHAP422-98 9 IDE drive will read but not burn CD/RW discs. No problem with DVDs or CD/R. One of two error messages, depending on the CD/RW disc: 1) Doesn't recognise a disk is in the...
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 14, 2011 | Lite On iHAP422 DVD+R Burner
When I plug in my hard drive it seems to be working bacause the light on it glows and it makes a silent working noise, but I can't find it anywhere on my computer, when I open My Computer it's just...
When you go to file explorer, and hit this PC the external device should show up. If the drive lost its formatting feature, you should see a notification that the drive needs formatting. If there is absolutely no values post on the computer screen regarding the external device attached to the USB port, then the DRIVE is bad and not communicating. Check the drive in some other device with a USB port, such as a smart TV.
Feb 17, 2018 | Memorex (32020013945) 160 GB USB Hard...
My MacBook doesn't recognize my new portable LG Super Multi Drive--GP08 Lite...There's no icon, and things aren't burning...Do I need to download a driver? Why doesn't this product tell...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 25, 2011 | LG SecurDisc 8x External Double-Layer DVD...
DVD drive not recognized as RW
If you use the Nero Smart start, you should see an icon to switch from burning CDs to burning DVDs. Once you click this icon, you should be able to burn to DVDs. Step-by-Step tuturials can be found for nero products here" Nero 7 http://ww2.nero.com/nero7/enu/Tutorials.html Nero 6 http://ww2.nero.com/nero6/enu/Tech_Support.html
Sep 16, 2006 | IBM ThinkPad T42 Notebook
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
