Question about Samsung DVD-L300 Portable DVD Player
Power and picture
Whenever i charge my dvd player or try to play a movie the screen show nothing. then the power goes off. even if the battery is charged there is still no picture. the pwoer light want stay on either. i'm try to figure out how can i get this problem repaired. i'm in iraq and can't even use my dvd player. is there some place i can send it to get it fix. it hasn't been dropped or nothing like that its just stop working. i had it for about 13 moths or lil bit more. i brought if from korea at a military store..if you could email me back i would be very happy. thanks raymond jones
SOURCE:
Agent Jason
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Posted on Jul 23, 2008
SOURCE: SAMSUNG DVD RECORDXER 120
Do you mean rso on the payer? You should have a button on the front of the dvd maked rso, press this three times to cancel the rso,it should then play.I hope this helps. Jamie
Posted on Mar 02, 2009
  • 48 Answers
SOURCE: I have a samsung dvd player combo. It's ab out 5
the eye wears out on them. if the eye gets damaged the lens will only read certain movies
Posted on Nov 30, 2009
Testimonial: "Thank you. I appreciate the input and it souns very logical. This was better information that I got from Samsung's tech."
  • 5603 Answers
SOURCE: My DVD player stays stuck on loading. How can I
If all DVD's you try act the same, I would clean the read head. If that doesn't work, then drive needs to be serviced. Hopefully nobody smked cigarettes near the unit as that coats the optics. Clean the read head VERY carefully with a Q tip and 99% isoprophyl alcohol. Ensure that no fibers get stuck around the read head... it is VERY fragile.
If only one disk won't finish loading, then the disk itself is probably bad and the drive is OK.
Posted on Jan 03, 2010
Testimonial: "Very helpful. We had a small kitchen fire that put out a lot of smoke, so that was probably the problem"
  • 76 Answers
try push both power on and eject hold for about ten second....
Testimonial: "Thanks! Yes, very helpful. We also used compressed air to clean things out."
When inshirting movies dvd in dvd player showing message on dvd players screen no disc and cant play movies dvd why?
it could be the disc itself dvds really don't age that well a common problem is that one day they just decide to freeze and stop working even though they had only been played a few times the most extreme would be your situation. I would suggest trying newer dvds out if same problem occurs then it is a problem with the dvd player.
Feb 06, 2015 | Philips Televison & Video
The picture comes on for two seconds and goes out
i have tried diferent movies plays for a few seconds then goes back to reload disk and continues on last memory and sometimes cannot load disk
Apr 08, 2009 | Insignia IS-PDO40922 Portable DVD Player
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Distorted picture
I am having this problem too any ideas
Jan 15, 2008 | Televison & Video
Craig portable dvd player CTFT701
My screen would flicker when you tilted it back and forth. Sometimes it would cut out and moving it would make it come back on. I took the battery off and opened the screen from the front(2 screws in hinge & 2 screws under rubber plugs). There is a ribbon plug inside. Mine looked kinked in one spot so I just repositioned it so the kink was in another spot. Everything worked fine after that. Hope this helps.
Aug 03, 2007 | Craig 731398407019 Portable DVD Player
Polaroid 0722 Player
On most of the set top DVD players you use the monitor button or the remote control menu button to access the mode that flips the display (invert). The mode is for those who mount the units to the ceiling of a vehicle for rear passengers to view. You might have to have a DVD playing at the time or just loaded in the stop mode to access the feature.
Jun 08, 2007 | Polaroid PDV-0700 Portable DVD Player
Screen won't play movie
sound like the wire to the parking brake may not be getting a ground.if it not get a ground it will no show a picture on the screen. it so you cant watch the dvd while driving.
Feb 11, 2007 | Concept DVD-168C Car Video Player
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Samsung DVD-L300 Portable DVD Player Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
