Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f11 code, replaced ccu and now won't go into diagnostics
Every wire has been checked. Every connection has been checked. Power to door latch, motor, ccu, mcu all have been checked.
the dr
  • 447 Answers
SOURCE: Whirlpool washing machine model GHW9460PWO, error code 11F
Yes it may be in the MCU but I had one do this and it was in the CCU. Has it ever thrown a Fdl ??? Door lock code?? Thats another sign its in the CCU
Posted on Jan 04, 2008
SOURCE: Whirlpool Duet Washer Error Code F-11
earlier i just researched code "dl" (door lock), the washer would not start, door would not lock. this site under this code failure came up with a Wiz called "Coldcut".
I took the motherboard out and searched around for the crack with a microscope, I found that every one of the relays had bad solder joints with micro-cracks around the legs. This did not happen due to wear or vibration.This was a new replacement board. It was just a bad solder job on the factory wave solder machine. QC issue.
After re-soldering all the relays legs I have run the machine for a month now without any issue.
So there it is the final fix for the dreaded door lock F dl issue. and likely any other random error issue.
Comment by Coldcut, posted on Jan 25, 2008 the constant clicking and then F DL failure is symptom
If you want to test that the relays have a bad solder joint as I had found. after opening the machine top metal cover ( 3 screw in top rear), on the front of the CCU motherboard push up on one of the white connectors that has the black wires gently .you can safely do this as this is the low voltage area,
the machine will then gain control of door lock and the front buttons will now work.
stay away from the pink wires they are 110volts.
Yes resetting the power to the machine will sometimes work but the failure will reoccur randomly.
Just mark all the connectors location and remove the board open the plastic and remove the board. flip it over and add new solder to all the relays ( white square boxes) legs. Reassemble and rest assured you have fixed the issue.
BTW if you need to open the door manually, unplug unit , remove top washer cover, reach down (tight area) and below the front door latch you will feel a ring, push it down and the door will open. the same can be done from the bottom access panel but you will have a cramp in no time.
Comment by Coldcut, posted on Jan 26, 2008 yes those white boxes are the relays that control the door locks.
but while you are in there soldering there is another relay off to the side as I remember re-solder it too. I found that any relay on the board had micro-cracks around the legs.
Comment by Coldcut, posted on Jan 26, 2008 Also can you take a closeup of the bottom of the board before you fix the solder joints to show folks the issue before and after. Comment by Coldcut, posted on Jan 30, 2008 On a side note I have found that this same board is used in many brands of top loaders.and have of course the same issues.
I have notified the makers of this model what I found and they are forwarding it to their engineers . sic.
Posted on May 08, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet HT needs new CCU
The CCU is simple to install, and "yes" you can order it form the same website as the door latch assembly. If the model number you have this listed under is correct, you can find a replacement CCU under the "Control Panel" heading as item number 15 (part number 8182280). I just got a price listing from the Sears website and you're not going to be happy with the cost. Repairclinic.com carries it for less, but its still a bit pricey. I've seen these boards sell for as little as $85. It just doesn't make sense to me. Anyway, if you decide you want to replace the board, the following information is provided:
To replace the CCU, follow these steps:
1. Leave the washer UNPLUGGED & remove the top panel of the washer, by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. The CCU is located in the middle, directly behind, and slightly above, the wash tub.
2. Swap all the connectors from the old CCU to the new one. The easiest way I have found to do this is to hold the new CCU in hand and swap the connectors one by one. Use care when handling the connector plugs and wires, they are fragile. There is enough enough slack to do this, but just barely.
3. Once the connectors are all moved to the new CCU, unmount the old unit and insert the new one. There are three tabbed clips that hold the CCU in place along the top. Just use a screwdriver and gently pry up to remove.
4. Insert new CCU (complete with connected wires) by snapping it in place in the mounting bracket.
NOTE: Another method of ensuring all the connectors are placed correctly, is to label each connector with tape or take a good clear photo using a digital camera.
I hope all this information helps you. Let me know if you require additonal assistance.
Posted on Sep 02, 2008
SOURCE: F 06 whirlpool duet washer
I had a similar problem.
The duet would always return an F06 error on the spin cycle(after about 1 min after doing the drain cycle). the motor would turn during the drain cycle for about 1 second and the other cycles acted somewhat normal.
Heres the solution:
The MCU uses the tachometer of the motor(rpm sensor) during the spin cycle only. It returns F06 because it can't read the rpm's. (for some reason it doesn't use it during normal cycles)
What I found out was that a resistor, believe it or not was bad. A 0.01 cent part to fix a 1000$ machine. (I wonder how much money has been wasted on this problem ;/)
The resistor is the first resistor that enters the mcu board on the tachometer. (I put the mcu back up before I could take a picture)
To find it, trace the circuit from the back side of the board where the tachometer wires come in at(its the 2 lower ones out of the 5 black + green(ground)). One of them will lead to a via(thing that goes to other side of board) which leads to a resistor labeled 471(470 ohms). On mine it looked slightly charred at the top almost like dirt and I didn't think about it but I finally put an ohm meter across it and it read open(should have read something).
After replacing it everything seems to have been working fine. What happened was that the tachometer wasn't being able to be read and hence the spin cycle wasn't able to start.
Replacing the MCU board would have solved it too but at a cost of several hundred(a total rip off specially for a 1 min fix if you have that problem).
Took me several hours to fix it so hopefully this will same a few others time. You can repay me by not buying from whirlpool!
Posted on Sep 27, 2008
57 varieties
  • 1653 Answers
SOURCE: 3 year old Whirlpool Duet - F07 error showing up
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Posted on Dec 30, 2009
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Mar 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My machine shows an f11 or f14 error code and it won't work. What can I do?
Circuit Board Medics can rebuild and upgrade the CCU to eliminate the F11 error and prevent it from happening again. Find more details at http://circuitboardmedics.com/whirlpool-f11-code/
This video shows how to remove the CCU from the machine.
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F11 code on a whirlpoos duet washer model GHW9150PW1. I replaced the CCU and still have the same problem. When I run a diagnostic test at the C01 stage is when the F11 error appears. Any help would be...
Might be a wire broken from vibrations or the MCU itself.
I have a service manual for you. Use the manual to reference repairs and your machine's tech sheet for error codes. This is your F-11 error from your tech sheet:
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
I have some more photos and repair manual for duet sport model HERE
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Brand new washer won't run through a cycle. Keep getting error code F11 each time.
F11--Motor control unit error
Possible Causes / Procedure 1. Unplug washer or disconnect power.
cycle.
7. Check the drive motor for powered rotations .
MCU connectors.
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 Code Showing
F11 is:
Check for:
Check MCU
Check CCU
Check Motor
Check Wire Harness
Courtesy:JSrock
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error message F11 what does this mean
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
5. Verify CCU operation by running a Diagnostic test or any cycle.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 CODE ALWAYS AND SHUTS DOWN
Here is what the F11 means.
cycle.
7. Check the drive motor for powered rotations 8. Check that the serial harness at the MCU is not mounted
MCU connectors.
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ERROR F11 (Whirlpool Duet GHW9300)
Hi there this is as it reads for your fault code F11
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check MCU
  • Check CCU
  • Check Motor
Feb 10, 2009 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
3,500 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
