Question about GE GLDT696TSS Builtin Dishwasher
GLDT696TSS dishwasher water does not fully drain and drain motor keeps running
micromaster
  • 3614 Answers
SOURCE: dishwashing machine not fully draining (2 inches of water remain)
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Posted on Apr 22, 2008
  • 142 Answers
SOURCE: Water won't drain out of dishwasher
outflow soloenoid stuck/ blocked, remove and clean/ replace as required
Posted on Jan 27, 2009
  • 464 Answers
SOURCE: my dishwasher won't drain fully
you may have a part on your machine called a piston and nut, it screws into the soil chamber. it has a gasket on it, and is likely worn from the hot water and you will need to replace this part. not an expensive part. without the model number, i can't say for certain that your machine has this part. but if it does, and it is worn away, all the water will not drain from the tub. hope this helps.
Posted on Oct 27, 2009
joe_lishman
  • 192 Answers
SOURCE: Dishwater not fully exspeeling from dishwaser
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning FREELY. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Posted on Mar 26, 2010
  • 3247 Answers
SOURCE: Drain stays open after start
Looks like a pressure switch problem. Refer part 26 in this diagram. The drain pump operates instead of the wash pump.
Posted on Sep 22, 2011
Ge dishwasher gldt696tss-00 green power light only.
Get enough water out of it to allow the float to go down so you can restart at the beginning of cycle is what I would try.
Dec 22, 2016 | GE Dishwashers
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
Samsung new dishwasher will not run through a cycle or drain properly. Water left in bottom. Keeps stopping and going to quick flashing.
The drain hose from the dishwasher may be partially or fully clogged with food stuffs like peas, corn, green beans, or other foods. disconnect the drain hose and clear debris from drain hose and run threw drain cycle.
Mar 16, 2013 | Dishwashers
Drain stays open after start so water doesn't stay in dishwasher for wash cycle. Model GLDT696TSS
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
Can start dishwasher but gets stuck on same time and water does not fully drain, can you please advise what solution there is thanks
When you say gets stuck - does the dishwasher stop all together or keeps running endlessly with same time displayed on the display.
Can you try with another cycle like rinse only. Does it complete cycle and fully drain water?
If so, the diswasher heater could be packing up. If you use hot water connection then see if you can increase inlet water temperature and run the normal cycle again.
Dec 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Ge dishwasher will not drain fully anymore i have cleaned all traps and motor/pump could it be something in the pump? what else could it be?
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 18, 2009 | Dishwashers
Whirlpool dishwasher is not fully draining after cycle complete
THE PROBLEM SOUNDS TO BE WITH THE INSTALLATION OF THE DISHWASHER ITSELF. YOU NEED TO MAKE SURE YOUR DRAIN HOSE IS NOT KINKED AND ALSO THAT THE DRAIN HOSE FORMS A LOOP. IN OTHER WORDS IT SHOULD GO STRAIGHT UP BEHIND THE UNIT AND THEN DOWN INTO THE SINK OR DISPOSAL.THIS SHOULD TAKE CARE OF YOUR PROBLEM.
Apr 07, 2009 | Dishwashers
Dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Drain pump won't stop
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
Nov 22, 2007 | Bosch 24 in. SHX36L05UC Stainless Steel...
Open Questions:
See all GE GLDT696TSS Builtin Dishwasher Questions
GE GLDT696TSS Builtin Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
