Question about Sony CDX-GT310 CD Player
Sony CDX-GT310 CD
Ive just installed this radio in my car but everytime i tune it in the following morning the stations are gone from the memory....
    Brigadier General:
  • 6,966 Answers
The yellow wire must be directly connected to an always ON B+12 such as the + terminal of the battery. This wire is responsible for providing power to the memory.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 25, 2008
WIRING DIAGRAM FOR SONY CDX-GT310
We do not have wiring diagrams. Sorry
Aug 19, 2015 | 1990 Toyota Cressida
Hi. I just need to know what the wires are at the radio. Power, memory,l/F speaker, etc. Thanks a lot! Jerry
If you are looking for harness details, click Sony Support to download installation manual for CDX-GT310 that has info of each connecting wires and if thats not what you are asking then let me know in details to provide you info.
Thanks.
Aug 22, 2010 | Sony CDX-GT310 CD Player
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
Radio and clock memory goes when engine is switched off
The radio was installed incorrectly or the memory wire has somehow been disconnected. The memory wire is the one which is connected to a permanent 12v feed even when the ignition is turned off.
The permanent feed is usually red, the memory feed is usually yellow (and a poor/lazy fitter may have piggy-backed it onto the red wire). Just connect the yellow to a fused permanent 12v source:either direct to the battery/starter motor terminal, or you can find others attached to the hazard flashers and often to the brake light switch on the pedal assembly.
Do yourself a big favour when doing the job and avoid clip on Scotchlok wiring connectors: they're a constant source of faults and no substitute for proper crimp-on bullet/spade connectors.
Feb 15, 2010 | Sony CDX-S2200 CD Player
Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
Could be a bad connection in between radio and antenna . Check that first . If that doesn't work try a film strip antenna
Jul 24, 2009 | Sony CDX-GT310 CD Player
CDX-GT310 won't take a cd.
If the motor runing full speed , but nothing happens you got a broken or slip belt.
Can be tricky to replace lots of dissasembley
Jul 05, 2009 | Sony CDX-GT310 CD Player
Need wirin diagram for sony cdx-gt310
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Here is the schematic you need.
I would advise buying the aftermarket wiring harness female/male so you can just plug it in.
Feb 08, 2009 | Sony CDX-GT310 CD Player
Storing channels and time display
* Connect Yellow wire to continues power ( it is back-up power to memory circuit)
* Connect Red wire to switched power
You can download User Manual and Installation Guide for CDX-S2000 from Sony Support for more information.
Oct 23, 2008 | Sony CDX-S2000 CD Player
Sony CDX-GT310. Installed by Circuit City about 15 months ago. CD works fine. No sound from radio (both AM & FM). I've manually tuned through the range of stations with no reception. Checked...
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Aug 11, 2008 | Sony CDX-GT310 CD Player
Sony CDX-GT310 CD Player Logo
150 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
