Question about Vulcan Convection Oven - VC44EC-208-3
Fan not working the oven no ignited - Vulcan Convection Oven - VC44EC-208-3
    New Friend:
  • 27 Answers
Toooooo vague sorry
Posted on Oct 28, 2013
My 7060 oven won't light. The electric igniter comes on but no gas.
an you hear the oven gas igniters firing? If not maybe there is no power to the oven. Not sure of your oven, but does it have an electric fan and if so, does it work? This should prove that there is power to the oven
What is the model number of your gas stove (oven/cooktop)?
Does your oven light work? If not does your oven have a separate power cord, i.e are there two power cords one for the cooktop and one for the oven?If so have you checked that the power outlet for the oven cord is working?
Mar 27, 2018 | Ovens
Replaced fuse and blown bulb,grill works as does the fan but the oven does not ignite.
You don't give make/model/year etc but can you light the oven manually with a taper?
Did you have an owners book with it?
I take it the igniter works the top burners?
Feb 16, 2016 | Ovens
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 | Ovens
Grill working but oven won't heat up, fan working ok. Is it fixable and how difficult would it be to carry out myself?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 11, 2010 | Ovens
My oven fan is making noise what should i do?
check to see why it is making noise. look at the fan while it is spinning DO NOT INSERT YOUR HANDS and see if you can see what the fan is hitting and why it would be hitting whatever it is hitting could be the shaft onthe motor is maybe bent or a blade is bent on the fan blade itself or maybe something fell into the fan and that might be makin the noise hope this helps
Jul 17, 2010 | Ovens
Broken oven
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Ovens
No ignition
EL HORNO NO SE APAGA EN LA TEMPERATURA SELECCIONADA Y CALIENTA DEMASIADO
May 20, 2010 | Imperial ICVD-1-H Turbo-Flow Gas Single...
My Maytag oven (mgs5870adw) isn't getting as hot as it should.The boiler works and all of the burners work. I haven't confirmed my problem other than noticing that things don't cook evenly and/or take way...
mlong9876 - I am having the same problem as you posted re: Maytag (mgs5870adw). I am trying to arrive at the same resolution changing the lower igniter in my same model oven. Were you able to remove the lower oven plate to access the top of the burner and igniter with the convection bake fan housing in the back? I am having difficulty getting to the igniter.
Mar 13, 2010 | Ovens
Gas oven will not ignite
It sounds like somebody bypassed the flame sensor on the oven, no oven should ever release gas for more than a couple seconds if there is no ignition. This oven is very dangerous and should not be used until it is looked at by a professional.
Dec 19, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Vulcan Convection Oven - VC44EC-208-3 Logo
Top Vulcan Ovens Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
