Question about Garmin SOFTWARE, MAPSOURCE CITY NAVIGATOR Maps Software
Problem viewing maps with Garmin City Navigator MicroSD/SD card on my nuvi 350
My wife is in Spain. She inserted the Spain
sd card into the Garmin Nuvi 350 and says it doesn't work? Any suggestions?
SOURCE: Audiobooks on a Garmin Nuvi 650 GPS
I am trying to download books on CD to my Garmin 650. How can this be accomplished?
Posted on Feb 06, 2008
  • 7 Answers
SOURCE: Can't unlock maps
What have you tried? without knowing anything else, one suggestion is to make sure you are using the correct unlock key number. There are at least three numbers located on the disk.
Posted on Sep 15, 2008
SOURCE: Can't unlock maps on the SD card
I am still waiting for the promised free solution suggestions
Posted on Jun 13, 2009
SOURCE: Garmin nuvi 200w can't update all 49 lower states
OK, I just finally am getting through all of this myself.
First, the bad news. You cannot load all of the lower 49 states onto your Garmin 200W as-is. The map file is over 1GB and the 200W only has 991MBs of memory.
So, go out and get yourself a SD card. I got a 2GB card at OfficeDepot for $8. It was at the counter, not back with the other cards they carry (Note: The speed showed as 60x. The slightly more expensive ones, $12-$15, may be faster, like 150x.)
You'll also need to get yourself MapInstall, available from the Garmin site. BUT, don't try to use this right away, a mistake I made. If you do, you basically get a message that MapInstall can't be installed because it's not already installed. Seriously.
BUT, MapInstall GETS installed, or whatever, when you load your 2010 maps (or partial maps), so after you do your partial install, THEN you can install the MapInstall program. (May not be necessary, but remember, I did this out of order. Look for a "Garmin" folder under your Programs, or All Programs, and see if it's already there after you install your 2010 maps.)
Next, run MapInstall. The next mistake I made was that at the window where it finds your device, I clicked on the NEXT button. DON'T. Notice that your device is shown in a drop-down box. Click on that, and you can select your SD card for the destination.
THEN click NEXT. On my system, it appears as if it shows you what IS already on the 200W, and lets you select whatever you want to add. I put everything else available on the SD card.
I just this minute finished loading "the rest" and checked it out. Works flawlessly. I easily found a seafood restaraunt in Anchorage (Alaska was not loaded in the intitial install.)
Just remember that you have to keep the SD card in the Garmin at all times to use those maps. That really shouldn't be a problem though.
Hope this helps eveyone.
JDCrownover
Huntsville, AL
Posted on Jun 17, 2009
  • 156 Answers
SOURCE: i have a garmin nuvi 760 and topo maps on a sd
tools.settings.map.map info
Posted on Jun 28, 2009
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
Nuvi 1490T Australia Maps on a chip
City Navigator 2012 is available preloaded on micro sd card.
http://www.gpscity.com/garmin-microsd-australia-and-new-zealand-city-navigator-nt-2012.html
Sep 22, 2011 | Garmin nuvi 200W GPS Receiver
Need to upgrade maps for ireland
The easiest way to do so is purchase mapping on a pre-loaded microSD/SD card and insert them into the unit. I recommend getting all of europe for the cost here is a link http://www.gpscity.ca/garmin-microsd-city-navigator-europe-nt-2011-card-with-adapter.html.
Hope this helps!
Mar 03, 2011 | Garmin nuvi 255W GPS Receiver
Need latest maps for new zealand
Here is a link to the SD card version. It is also available on DVD. SD card is the easiest to install and use. The SD card version can also be transfered to other Garmin units like the Oregon 450 if you plan to go hiking, boating, or geocaching!
http://www.gpscity.ca/garmin-microsd-australia-and-new-zealand-city-navigator-nt-2010.html
Cheers
Jul 12, 2010 | Garmin nuvi 250W GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Garmin Map loading
Nope, the data will stay there, you just insert the SD card, use the wrench symbol/select map/select about/ tick the Australia map on/the usa map off/ and you're garmin just went Aussie.
Apr 23, 2008 | Garmin nuvi 350 GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Countries
Go to the wrech symbol, tap, tap map, tap about, see the spain map. Is it checked, if not check it by tapping it.
Dec 01, 2007 | Garmin nuvi 350 GPS Receiver
Uploading European City Navigator NT v9
Your best be would be to load it to an sd card.
Oct 22, 2007 | Garmin nuvi 350 GPS Receiver
Garmin SOFTWARE, MAPSOURCE CITY NAVIGATOR  Maps Software Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
