Question about Sewing Machines
How do you fill the bobbin on a 9117 singer sewing machine
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
Model 9117. Why won't it sew?
Remove all the thread. Raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk. Confirm with the manual that the needle is inserted facing the correct way and verify that everything is threaded correctly. Somewhere I read to use only Singer needles in Singer machine--don't know if that's true, but...
Also appears that this machine takes a special bobbin:
Sew What Up View thread Singer 9117 Sewing Machine
There could be a knick or burr somewhere that is catching the thread. You can test it by lightly rubbing an old pair of pantyhose on areas (under the needle plate) and see if it catches anywhere. If the knick is not bad, you can try to smooth it with a fine emery board. Otherwise, could require a replacement part.
If you can, observe the stitching mechanism while you hand-rotate the handwheel and see if you can tell where the thread is hanging up. Hopefully you will be able to see where the machine is failing to operate.
Dec 17, 2015 | Singer Sewing Machines
Model 9117. How do I wind the bobbin?
this question is under the singer category,, so here is a link for a singer manual,, http://www.singerco.com/uploads/download/410_317218001.pdf
May 26, 2015 | Singer Sewing Machines
How to fill a bobbin on model 9117
Download the user's manual from the Singer website. You can get it free.
Oct 20, 2014 | Singer Sewing Machines
How can we wind the bobbin singer sewing mashin model 9117?
Here is a link to a free manual for this machine. Page 9 shows how to wind a bobbin.
Sep 02, 2014 | Sewing Machines
Singer sewing machine model 9117 DV
Wow... that is a problem (ha ha ha)
Could you please clarify your problem? In case you just need a manual... here's the link for a download pdf.
Jul 19, 2012 | Singer Sewing Machines
Filling bobbin
is it still under warrenty where you can take it back?
Apr 09, 2012 | Singer 1507
How to fill bobbin on singer 9124 sewing machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9124 ) & click search
Mar 25, 2012 | Singer Sewing Machines
I have a Singer 9117. The lower thread keeps bunching. I have tried taking the bobbin case out and putting it back in. I have also tried rethreading the machine. Do you know what else I can do?
Hi, I have the very same problem with my 9117DV. Which I paid 300.00 for 2 years ago. It sews great when it works but for some reason it will bunch up and jam right in the middle of my sewing project.
I have the exact same machine in an older model and I have never had this problem.(which prompted me to get another).
The only solution I have to offer is take it to an authorized Singer dealer or sell in on eBay which is what I am doing!!!
Feb 01, 2011 | Singer Sewing Machines
Sewing Machines Logo
717 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
