Question about Apple iPhone Smartphone
Iphone does not connect to wireless networks anymore
My iphone dropped in water. since then it dried and now works just fine except it won't connect to wireless networks with or without passwords. is there a setting that needs to be adjusted or something else?
  • 14 more comments
  • telefon Oct 27, 2008
    the iphone finds the wireless networks in any area and tries to connect but can not connect. it also does connect to the internet via the phone carrier service. so would it still be the internal antenna problem as one guru suggested?
    the iphone does detect the wireless networks in any area and tries to connect, but cannot. it also connects to the internet via the telephone carrier's service. so I am wondering that if the internal antenna is faulty, how can the phone detect the networks?
    I already reset the settings and same problem continued.
    i did not understand the last solution. which other part of the phone?
    if the antenna (not the phone's) is bad, would the phone still be able to detect the wireless networks in an area?
    can anyone help me with a setup to make sure that my problem is indeed the antenna?
    how can I open the housing ?
    how can I manually change the wifi channel?
    okey the last guru gave me a good tip. my problem does not appear to be with the antenna since as i got closer to the router, I got connected and stayed connected even when I walk away.however the internet speed drops when i walk away . everything works when I am close.
    when I get really close to the wireless router, iphone gets connected and the internet access is just fine, but when I walk away , even when it shows that the iphone is still wifi connected, the hourglass (or rather hourwheel) keeps turning and internet cannot be accessed.any ideas?
    i am connecting when i am very close to the router only.
    how can i take the battery out??
  • telefon Oct 28, 2008
    i have two questions at this point then.
    1- as some of you have suggested, doing a factory restore may be the last resort before being definitely convinced that it is a hardware problem. in doing so, how can I backup my contacts? i backupped my photos in a file on my computer but couldn't find the option for my contacts.
    2 - if factory restore fails, how can I open the housing (or should I even try?) and try to dry the wifi antenna or anything else?
    thanks for all the advise
    my router is on channel 11
    electech,
    please let me know how I can take the housing out so that I can dry the battery and more??? I definitely want to try drying the battery since I tried drying the iphone for days before I got it to work at all.
    I have the same type of phone that you have sent pictures of.
    i am overseas and my warranty is expiring any day now. I had bought it exactly one year ago. I am hesistant to take it to an apple store here but maybe I will try drying it even more to see what happens. any idea about how much Apple charges to fix internal antennas??
    i see no screws
    Problem Solver:
  • 5 Answers
    Sergeant:
  • 306 Answers
My experience is that this is an Exchange server issue with the way the SMTP connector authenticates the iPhone users credentials. Try changing the SMTP connectors authentication from "Windows Authentication" to "Password sent in clear text" (make sure to stop and start the SMTP connector) -- no changes are necessary on the iPhone.
for more clik out http://securosis.com/2008/04/28/iphone-security-tip-never-memorize-wireless-networks/
Posted on Oct 28, 2008
    Genius:
  • 1,226 Answers
It is probably good idea that you contact the nearest repair center in your area for an ultimate solution of iphones.
melnavz
    Genius:
  • 3,422 Answers
HI,
It will cost you anything between $100-$150.
If you need anymore help let me know.
  • 47 Answers
Well happy to help u . as u know u have a new phone just go to the service center.and don't tell them u dropped it in water. just say it rained and mositure got in ur phone.get it fixed for free. coz if it was security setting u could not use it before. so it could be some chip on in ur cell more like ur wi fi is fried,or internal antenna.pleasure helping u.
  • 728 Answers
You might have messed up the wireless receiver when it was dropped in water. See if you can find any signals near a wireless network and then see if you can connect. Make sure it does not have any security settings because it wont let you on any way. If that does not work, try resetting your wireless connections and try logging on then. If that does not work, then you might need a new wireless receiver.
Posted on Oct 27, 2008
  • Jazz Boyce
    Jazz Boyce Oct 27, 2008
    Are you sure you want to take the battery out yourself? You could damage a whole bunch of other things while opening the iphone and disconnecting the battery. you should get it done by a professional but if you really want to do it, here you go: pop of the back case slowly with a credit card or something that will not scratch the back or sides of it just in case there is something that is connected from the rest of the iphone to the back cover, and once you get the back cover off, you should see the battery in there. You should not disconnect it unless you have a soldering tool to reconnect the cords because i think it is a soldered connection.
  • 928 Answers
Based on your last comment. The problem could indeed be the antenna. Its not able to pick up a signal from a distance any longer. This type of problem happens with wireless routers and adapters as well as time goes by. So the water damage may have degraded the antenna to a point that it will work no question but the distance that it is able to pick up a signal and sustain a connection has lessened. An option to fix this is to possibly update the Iphone software via Itunes although its going to be a long shot. Another option is to just have the antenna replaced.
  • Thomas Lim
    Thomas Lim Oct 27, 2008
    DId you see my response?
  • Thomas Lim
    I would not suggest that you take the battery out. First thing is that it will completely void the warranty. I would assume that your unit is still under warranty since the Iphone just came out recently. You can have the antenna replaced under warranty. if its not under warranty you could also risk damaging other parts that you are NOT having a problem with thus compounding the problem at hand. the best thing that you could do is to just take the unit to an Apple center and have the antenna replaced.
    Master:
  • 505 Answers
It is very likely that the wireless device of your iphone has got damaged. I would request you to get it checked by some professional technican or contact the manufacturer directly.
Thanks
    Master:
  • 538 Answers
Anyone check this guy out? he does solutions for iphones...a new expert in the making, perhaps?
    Genius:
  • 1,268 Answers
The wi-fi chip inside is already shorted due to water penetration. If you can take apart the housing of your phone, you can use a blower (cold air) to thoroughly dry the internal chips. That one is located on the top near the power switch. Or leave it bold (without the housing) for about half a day just to make sure it's realy dried up.
Another thing you can try is check on the wireless settings of your unit if you can manually select or change the wifi channel. Use channel 11 if there's an option like that.
  • 899 Answers
Once the water has got in there it has ruined components , if you take out the battery and leave it open for a long time it may work again , but if not then it is ruined , there is no way to fix it but replacing it will be the only way
sorry , but that how these electronics are these days
electech
  • 12 more comments
  • jason Oct 27, 2008
    the problem is that there is still water in it , you need to let it dry before you permanently ruin it!
    the best thing you can do right now is pull the battery out , take a hair dryer on low and dry out the phone more , when you dropped it in the water you may already have ruined the antenna recieving and sending controling IC, these chips require very little power for them to work and being that water can conduct elctricity , it is causing the antenna not to be able to recive a good signal
    so if you don't dry it out then you will ruin your phone , guaranteed!!!
    if this is the same type iphone , then this where the antenna section is , make sure its dry and wait a day to be sure that even under other components will be dry
    here is the battery section
  • jason Oct 28, 2008
    if you have a warranty , you should only have to pay for it to get there( s&h) , but ask them how much ayway
    if the antenna proccessing section of the phone is effected they will have to replace the main board
    not just the antenna
    just tell them you can't recieve signals anymore
    mainly you should be drying the phones insides not the battery so much , but not high heat
    the back should pop off and don't have screws holding it down , just be careful when you pop the back off , as it can crack easily
    there are two screws!
    <object width="425" height="344"><param name="movie" value="
    ok three
    did you see the video? it shows you where the screws are
    they are very small so you would need like a glasses repair kit "screwdriver"
    ofcourse you don't have to go that far!
    as long as you get the first one open don't worry about the screws then , just blow dry it out with the antenna cover off
    make sure to turn it off and take the card out and dry it thru the card slot also
      President:
    • 1,952 Answers
    Better u check ur board whether the liquid affect any components in board?if its means replace thta and use..
    • Apple Master
    • 19,396 Answers
    If this happened afte the Iphone dropped in water, that means that the wireless antenna (separate from the phone one) wirings had been damaged, either by a short when the Iphone came in contact with the liquid, or by oxide formation after you dried it up.
    The Iphone mut be inspected and tested internally to be repaired.
    Check if you can still use your guaranty, and call the phone number listed on the owner manual to find out it there is possibility or guaranty extension, and the eventual cost of repair.
    • Ginko
      Ginko Oct 27, 2008
      If it is the antenna then you get weak signal, if signal is excellent when you get near to the router, then it is not the antenna.
      Reset the Iphone to factory settings and establish connection again, this should sort it out if it is a settings problem.
      If this does not fix it, as the fault cohincided with the water damage, then it is probably a fault related to the internal wi fi adapter, that is a separate circuit from the phone receiver.
      Here is how to reset the Iphone :
      To restore iPhone and reset the phone to default factory settings, follow these steps:
      1. Turn off iPhone - Hold down the Sleep/Wake button
        for a few seconds until the red slider appears, then slide the red
        slider. Ignore this step if your iPhone is already off.
      2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
      3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
      4. Run and open iTunes if it’s not already opened yet.
      5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
      6. You will be taken to the iPhone pane. Then, click on Restore.
      7. Wait for the full restoration process to complete, and the iPhone
        will be back to the original settings state as when it left the
        manufacturing factory, typically a working phone again if you face any
        problem, unless it’s hardware related.
      From Reset and Restore iPhone
    • 1,879 Answers
    Looks like it's working normally ? Other part of the phone that got wet maybe but not for others. This is what your case is.
    Electronics and Water don't get along 100%
    • Apple Master
    • 6,487 Answers
    If you already tried conencting to 2 or more wireless network and still it wont connec the next stpe that you can do here is to reset the settings of iphone and then after that try to connect to any wireless network....
    • Mark Gil
      Mark Gil Oct 28, 2008
      If you can also adjust the wireless settings of your router like changing the wireless channel of your to channel 11 and check if after that your iphone will be able to sustain the wireless connection when you move away from it...
      President:
    • 2,712 Answers
    It would appear that the internal antenna is faulty and will need to be repaired.
    My iphone will not read the sim card. The card works fine in another phone. My phone was submerged in a tub of greasy water and i am tryinng to restore it now.
    Ben, Could you try dry it first? Do not turn on.
    As you said that your card is not read by iphone, i can see that you already turn it on after it submerged in greasy water. I hope it doesn't short circuit yet. Use hair dryer, dry your iphone through the usb connection hole, leave for awhile, make sure it dry, then try again. Hope this will help. For future, if phone dropped in water, first thing to do is take off battery, or turn of completely then dry it before checking it still work or not.Thanks for reading.
    May 18, 2011 | Apple iPhone Smartphone
    Tip
    How to connect an iPhone to the Internet
    Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
    Your iPhone can either use WiFi or Cellular for internet access.
    - A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
    - Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
    To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
    I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
    Regards,
    G33k
    keywords
    how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
    on Jul 09, 2011 | Apple iPhone Smartphone
    I dropped my iphone in some water and there is no damage except for water is noticeable on the screen. i tried drying it out with rice over night but the water is still there. what can i do? can i go to an...
    The Apple Store does not touch these phones, they ship it directly back to Apple to replace. The rice in bag trick is generally a good idea with the exception that the iphone doesnt have a removal battery which hinders the effectiveness. But if you want to go the free route, leave your iphone in rice for a couple days.
    Nov 18, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
    No reception on cell phone "No Network Service"
    You need to check the RF. The RF is a component that pick up the signal. It is usually placed on the upper portion of the phone where there's a small exhaust so that the RF could pick up the signal better.
    Once the RF gets wet, the component might become defective.
    You need a phone tech to check or change the RF.
    Have a great day!
    May 27, 2009 | Sony Ericsson w580i Cellular Phone
    When i select my Linksys WiFi connection on my Iphone I still has the "E" edge symbol on my Status bar even though wifi is selected.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    Do you have problems connecting to any other wireless network with your iPhone?
    Have you tried using the forget this network option on your iPhone for your wireless network followed by trying to connect to the network again, and/or using the reset network settings option on your iPhone which erases all previously saved wi-fi connections that you have successfully connected to with your iPhone?
    Let me know....
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Apr 22, 2009 | Apple iPhone 3G
    Non responsive touch screen on iphone
    i guess ull jus have to replace the screen
    Dec 08, 2008 | Apple iPhone Smartphone
    If a hard reset (press menu and center button together for 5 sec) and software restore doesn't cure it , you have a broken digitizer of your iPhone screen assembly. There is an iphone repair guide website that shows you how to do the replacement yourself and a third party iphone repair company that can do it for you.
    WIFI Connection Problem - connects only to EDGE
    If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
    Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
    And simple follow the same steps and revers the process when your out on the go.
    Thanks
    Oct 15, 2007 | Apple iPhone Smartphone
    Re: IPhone doesn't connect with wifi automatically - password not recoginized HELP!!!
    Yep, I had the same problem with my iPhone as well (32GB 3GS).
    Had the signal NO problem for about a week then POOF it was gone. WTF?
    Prowled the boards looking for a solution.
    Tried resetting the phone, resetting the Wi-Fi, switching airplane mode on and off, forgetting the network, etc.
    HERE'S YOUR SOLUTION :
    Go unplug your wireless router's power cord.
    Wait 30 seconds.
    Plug it back in.
    Your iPhone will reconnect, and you'll be back in business.
    Jack
    Jul 15, 2007 | Apple iPhone Smartphone
    Apple iPhone Smartphone Logo
    147 people viewed this question
    Top Apple Cell Phones Experts
    Lesley Cameron
    Lesley Cameron
    Ed Nelson
    Ed Nelson
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
