Question about Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard
Front audio is not working - Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard
  • goununo
    goununo Feb 17, 2012
    Apparently it is an issue with this board, but I haven't found a propoer solution so far. Everything is connected but the front audio plugs won't work. The rear ones work fine.
    Top Expert:
  • Biostar Master
  • 76,673 Answers
If the rear plugs work ok then it is unlikely the problem is with the motherboard.
Posted on Feb 17, 2012
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
917-Front Audio Not Connected Problem with the HP Compaq dc7100 PC Desktop
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
Apr 20, 2011 | HP Compaq dc7100 PC Desktop
I am using windows 7 32bit. now my front audio
you need to right click the audio icon on the bottom right under windows 7 and then select default audio output device as headphones that you have plugged in the front. unlike that in windows xp both rear and front jacks were active at the same time in windows 7 you need to select the same manually.
Jun 23, 2010 | Intel D945GTP Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
My front audio is not working in my pc
If it works in rear audio port than for sure your front audio port from the chase it is not connected to the sound card, you have to open the chase and check this
Jul 18, 2009 | ASUS M2N-MX SE Motherboard
Not work audio front panel.What`s the problems. How to connect cables in motherboard. please help
The front audio panel will only work if connected to motherboard. Try
connecting to the audio panel in the back of the computer (directly
to the motherboard). If the rear panel audio plug (green) doesn't work
then the audio drivers that came with the motherboard might need to
be installed. Check your audio driver status with operating system.
Jul 08, 2009 | Abit GD8 Pro Motherboard
Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Jun 03, 2009 | Intel D865GBF Motherboard
Headphone problem
Did you installed all drivers ?
Are there FRONT audio jacks you are trying to connect your headphones/mic ?
Dit it work before ?
First install all (incl. audio) drivers and try to get audio from BACK connectors (Green is speakers/headphones, Pink is Mic.)
If it workson on REAR, but not on FRONT connectors, check if you have another icon for AUDIO settings in Control panel and try to set FRONT audio settings.
Check if FRONT audio connectors are connected to your motherboard.
Regards.
Check
Mar 28, 2009 | Intel Motherboard, G31 Express, Core 2...
Front audio ports not working.
What motherboard is it/ Normally there are jumpers that you have to move to select wether rear or front audio is used. Should be in the user manual. :)
Dec 22, 2007 | Intel Motherboard
Problem with front audio, i get sound with the back panell but not form the front the speakers and head phones work fine please see if you can help thanks
In some boards I've seen, the front connectors are not connected by default.You may need to review the manual.
Oct 09, 2007 | Intel Motherboard
Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard Logo
54 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
