My hp vs19b monitorscreen wont pop up the power button just blinks
Hard drive turns on, monitor does not..theres pwoower but the button just blinks blue
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: HP 19" Monitor Blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
budmrtn
  • 11361 Answers
SOURCE: hp vs19b monitor wont come on
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 12, 2010
budmrtn
  • 11361 Answers
SOURCE: MONITOR WON'T TURN ON
More likely to be in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 26, 2010
budmrtn
  • 11361 Answers
SOURCE: hi Brian I haave a 19 inch HP vs19b monitor..it
Monitor power light is not on, then it will not be the computer problem.
You need to check the main AC fuse and DC filter caps on the power supply/inverter board, see if it has any cap with bulging tops.
Here are the samples of failed HP monitors:
http://s807.photobucket.com/albums/yy352/budm/HP/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Sep 27, 2011
How to you fix a broken power switch on monitor
you need to remove the cover to access the power switch and to replace it..
Jun 05, 2012 | HP Vs19b LCD Monitor P8726A3ABA vs19b
My laptop wont turn back on. when i hit the power button the lighting bolt icon in the bottom corner with flash but it wont turn on. How can i get it to turn back on??
Are your LED's coming on like it is trying to read your hard drive? There should be an LED for power on, one for charging, one will blink when the hard drive is reading, etc. Are any of these working?
Feb 08, 2012 | HP Computers & Internet
Hi Brian I haave a 19 inch HP vs19b monitor..it was working fine..turned it off and the next time it would not go back on...the power button does not light up...monitr is about 5 year old but in perfect...
chck leads from motherboard to hard drive ide/sata including electrical and extensions if its a 40 pin flat ribbon type this will be the first to fail even something
as smalls a faulty fan or the fans electrical lead can cause this problem
make sure your graphics card is securely and the socket is dust free
hope this helps
Sep 27, 2011 | Computers & Internet
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Hp vs19b monitor wont come on
Apr 12, 2010 | HP vs19 19" LCD Monitor
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion Vs17 LCD MOnitor
an answer to this problem would be great because mine does the same thing...like blinks but monitor wont come on.
Jun 23, 2008 | HP Pavilion F1703 17" LCD Monitor
F1523 power light blink
resit your ram if the problem perssit then remove the video cable which is attaching to the cpu,check for any message in the monitor(monitor should be power on),if you are getting any message then your motherboards's display adapter has malfunctioned, send it for repair
May 14, 2008 | HP Pavilion F1523 15" LCD Monitor
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
