Question about Transmission & Drivetrain for Acura TL Series
Whats the best way to pull a transmission out of a 02 acura tl?
Removing transmission
SOURCE: 2004 acura tl, the transmission
Bad tranny like the 99 to 2003 tl's.
Posted on Aug 23, 2008
MrScary66613
  • 1990 Answers
SOURCE: filling transmission fluid
Should go into the Same Hole that the Dipstick comes out of. You are gonna need a Funnel to accomplish this.
Posted on Dec 31, 2008
  • 416 Answers
SOURCE: how to remove door panel on 1997 acura tl
Follow this link. There is detailed step-by-step info here
Please kindly let me know if it works for you
Good Luck
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008c18d
Posted on Jan 31, 2009
SOURCE: cost to replace 2002 Acura 3.2 tl transmission
your car could still be under warranty depending on the miles the car have call your Acura dealer for info. I had my transmission replaced in Feb 09 and it was done for FREE!!
Posted on Aug 07, 2009
ZJLimited
  • 17970 Answers
SOURCE: 1998 Acura TL 3.2: where
1998 Acura TL 3.2L MFI SOHC 6cyl
The Vehicle Speed Sensor is located mounted on transmission, front, driver side...
Look some sensor harnesses LIKE THIS
Hope helps.
Posted on Nov 09, 2010
What's the best replacement tranny for the 2002 Acura Tl-s? I was told that honda pilot has one that makes the best replacement, but I don't know from what year or even it's true.
2002 Acura TL Recalls - Motor Trend
www.motortrend.com > ... > Acura > TL > 2002 Acura TL
Motor TrendFind complete 2002 Acura TL specifications, pricing, and photos including ownership costs, safety recalls, cash rebates, warranty, packages/options, standard features, and crash test ratings. ... Base Sedan, Type-S Sedan ..... IF DISCOLORATION EXISTS, THE TRANSMISSION WILL BE REPLACED IF DISCOLORATION IS ...
2002 Acura TL 3.2L 0-60 Attempt (Slipping Transmission ...
? 1:35
https://www.youtube.com/watch?v=fzYACqnupzk
Jun 9, 2011 - Uploaded by Intechdude300
2002 Acura TL This TL comes with a VTEC 3.2L SOHC V6 which pumps 225 HP ... That honda I had was the only one I hadproblems with. .... 2001 Acura 3.2TL Type S B7WATransmission with P1768 CPC B - Transmission ...
Nov 04, 2015 | Honda Cars & Trucks
What does a A13 code mean for a 2004 Acura TL?
Hello there,
It simply means you should replace the oil and transmission fluid.
All the best Elect_Comp
Sep 13, 2011 | 2004 Acura TL
How to change oxygen sensor on Acura 1999 TL
Hello and Welcome to FixYa.com
Special Tools Required
02 sensor wrench, Snap-on YA8875. SP Tools 93750, or equivalent, commercially
available.
1. Disconnect the primary 14025 4P connector (A), then remove the primary H025 (B).
2. Install the primary H025 in the reverse order of removal.
Thank you for using FixYa.com
Regards, Lee Davidian
Your FixYa Expert
Jan 15, 2011 | 1999 Acura TL
My 2004 acura tl shakes as it goes into 3rd gear (automatic transmission). I took it to the dealweship and they say I need a new transmission. Also, my check engine light is on and sometimes flashes. I...
get car scanned for free at a parts place for failin sensors-02 mite need changin--giv it a tuneup like inspecting ign coils or worn plug cables-also dirty injectors can create vibration and improper combustion
Sep 20, 2010 | 2004 Acura TL
My check engine light and TCS light came on in my 1999 Acura 3.2TL. I had the code cleared out and it appears to be running fine. The code came up 1705 Transmission sensor out of range. No one including...
acura 1999 3,2tl .check engine light on ,my computer show code P0141 , 02 HEATER CIRCUIT, [BANK 1, SENSOR 2] please to help find problem .thank you
Mar 16, 2010 | 1999 Acura TL
What type of transmission fluid is needed for 1998 acura tl 2.5
Best source is the owners manual.
Acura part # Z8001-88443 is the OEM.
also: Honda Z1-ATF
From statracing.com: Dextron iii Type IV and Mercon
premium sythetic low viscosity slip lock type ATF.
Oct 29, 2009 | 1998 Acura TL
Starter replacement on acura 2000 TL 3.2
This starter can be changed without disassembling the top of the engine on the 2.5 with automatic transmission. You will need a 10mm, 14 mm, 17mm, and a 9mm wrench. First with any electrical repair disconnect the battery at the negative terminal. The starter is on the driver's side close to the firewall below the intake manifold. Remove the transmission dip stick so you don't ruin it, then look and study the starter itself. You will notice the starter drive housing with a top and bottom bolt. The top bolt is a 14mm and the bottom a 17mm, loosen both a half turn. Remove the top 14mm bolt first, then the bottom 17mm, this will allow you to pull the starter out of the bell housing. With some angling and no brackets holding the back of the starter you should be able to pull it out enough to disconnect the positive wire and 9mm nut from the soleniod. Disconnect the starter ignition small wire by pulling it off it's connector. Now just pull it out of the engine and fender void and you've got it, saving about a hundred and fifty dollars of labor. Take it to the parts house and match it up with a well made remanufactured or new starter. Reverse the proceedure, hook up the battery.
Mar 19, 2009 | 2000 Acura TL
1997 Acura TL Airbag Control Module removal
First of all removing of radio will definitely give you alot more room. (rememeber you will nee radio code after you unplug radio) I would recommend that you disconnect battery before you EVER work on air bags. This module is pretty simple to remove but it is help by Special TORX screws. after removal of screw it its a yellow latch to pull across and unplug. Good luck thanks for using FIX YA
Jan 11, 2009 | 1997 Acura TL Series
Transmission & Drivetrain for Acura TL Series Logo
41 people viewed this question
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 TE5LA
TE5LA
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
