Question about Pentair 1 HP Challenger Pump
Challenger pump leaking at the band
Cannot tighten band enough to stop leak at seal plate
  • 366 Answers
You may need a seal plate o-ring or you may have a shaft seal leak. See if you can determine if there is water running down the outside of the seal plate from where the motor mates to the seal plate.
Posted on Feb 16, 2012
How hard is it to change the motor out in an Emerson pool pump model k63cxese4793 (Challenger Pyrex triton)
NOT tat bad, (first x2) shut breaker off next take off the stainless steel band, pull motor and seal plate back from plumbing portion use wrench on back of the shaft of the motor, impeller screws off to the left, take out 4 9/16 bolts that attach the motor to the seal plate, give seal plate a tug and it should separate from the motor. use new seals especially the shaft seal (the one w/the spring in it) and put it back together. tap on the SS band this allows it to evenly pull up around the tank body lastly FILL PUMP (prime) with water.
or search for your LOCAL POOL PUMP MOTOR REPAIR GUY. and ask about installing the motor on the seal plate.
I charge $20 and it includes the shaft seal (most pumps)
Apr 19, 2017 | Emerson Pool & Spa
My disel van nissan e 25 Radiator water laval getting low But no any leak at radiatorI I change water pump 2 mouth a go any solution
Sometimes the leak can be so small it only leaks when driving.
It can be that the water pump was not sealed correctly or bolts not tighten enough or a hose clamp needs to be tighten more.
Jan 22, 2016 | Nissan Cars & Trucks
I have changed the o ring three time and I cant get it to stop leaking. Two new o rings installed....still leaks. large o ring sx200z7
Had problems with these types before also. As the filter ages it warps and thats a problem lol.
You said you cleaned the recesses Im hoping top and bottom and lubricated the recesses IN addition to the o-ring, don't hold back on that lube either. And lastly although it sounds odd, dont over-tighten the nuts, tighten them slightly over hand tight turn the pump on for a bit leaking everywher tighten everywhere, leaking in one spot, tighten only that one spot a little.
Putting on all that lube doesnt do too good when it spits it out from pressure.
Also pics next time, and good luck!
Nov 12, 2015 | Pool & Spa
My new pump leaks around seal plate
Leaking wet ends are a result of a bad shaft seal.Check to make sure it is installed properly or install a new shaft seal to prevent more leakage.If the motor runs and it will draw the leaking water into the motor and ruin your motor.Change the shaft seal as soon as you are able to prevent further motor problems.
Rod
US Parts Center
888-521-6813
Mar 02, 2013 | Pool & Spa
I have a 2hp sprinkler pump that I am having trouble priming. I have 2 check valves on in the water by the intake and the other by the pump. It has take a few hours to get the water to the pump but still...
1. You only should have one check valve; the one in the water is best, remove the other if you can.
2. Make sure there are no leaks in any of the piping between the water and the pump inlet.
3. Take the pump apart, thoroughly clean the new seal, the two halves of the pump that go under the metal band, the inside of the metal band.
4. Lubricate the new seal, the outer sides of the pump halves where the metal band squeezes together, the inside of the metal band where it contacts the halves and even the screw on the tightening device using petroleum jelly (Vaseline) or equal. Make sure the pump literature does not recommend against whatever you use.
5. Reassemble.
6. Fill the pump with water, open the discharge on top of the pump if possible and prime.
Normally, a pump, even with a long run will prime in 5 minutes or less.
Write back.
Your FixYa Texpert,
Gary
Aug 22, 2011 | Flotec Corrosion Resistant Convertible Jet...
I have a sta-rite p6e6F-207L pool pump - I have a leak where the tank body assembly is clamped together with the Seal plate. I have tightened the clamp down as far as it will go and it does not resolve...
THIS IS MY FAVORITE PUMP, THERE IS A O-RING CLICK EBAY
BUT YOU NEED TO SEE IF ITS NOT THE SHAFT SEAL THAT'S LEAKING FIRST THIS IS THE SEAL THAT NEWER STA RITE REQUIRES CLICK EBAY .. READ THESE ADS THEY HAVE SOME GOOD INFO IN THEM .. DO NOT OVER TIGHTEN THAT STAINLESS STEEL BAND ! THERE IS A CHANCE OF CRACKING THE PUMP.. NOT COOL ! AND NEVER USE TREAD TAPE ON THE PLUMBING, IT BUILDS UP ON THE FITTING AND CAN CRACK THE PUMP.. SO THESE ARE THE FIRST THINGS I WOULD REPLACE ON THAT PUMP. AND REMEMBER TO PRIME THAT PUMP WITH WATER AFTER ANY PUMP REPAIR !!!! IF I WAS OF HELP JUST CLICK ON THE (YES) OR LEAVE A COMMENT .. I GLAD TO HELP . SEARCH MY OTHER SOLUTIONS ALSO .. JAY .. THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA.. THE SIGN OF A BARK'N GOOD DEAL
Jun 20, 2011 | Sta Rite Pool & Spa
Inter seal won't let the pump close
you..you need to lube the seal, it may be that the seal has been damaged by chlorine and may need a new one, these pumps are fragile so do not over tighten the ss band ,tap it lightly with a hammer as you tighten it all the way around..and prime THE PUMP WITH WATER AFTER ANYREPAIR !
Mar 08, 2011 | Pentair 1 HP Challenger Pump
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Flashing green light
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Mar 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Pentair 1 HP  Challenger Pump Logo
320 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
