Question about Charging & Starting Systems for Audi 80
When i disconnect battery my audi 80 stops,battery goes flat when lights are on quickly,i know alternators is ok
Could it be a fuse or a relay?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audi Master
  • 1,449 Answers
Do you mean you disconnect your battery ,while the car is running.you can damage the cars ECU doing that .or do you mean your battery ,is losing its charge when diconnected.
Posted on Dec 02, 2013
Battery goes dead in about 4 days in 1996 buick park ave
most obvious cause could be the alternator ,one of the diodes has gone draining the battery or the battery itself its difficult to know without checking it out .Try disconnecting the battery and if it still goes flat then you know its a faulty cell in the battery .if it doesnt then try disconnecting the big thick cable on the alternator and see if that stops it
Dec 26, 2012 | 1994 Buick Park Avenue
I have a crazy case of parasitic drain.When driving, power drops, going reverse is even worse.When parked,the battery is drainned beyond recharging, the car has killed 3 optima batteries.
Normally what you do is to take off one battery terminal cable, and them put a test light across the gap between the cable end and battery post it was removed from.
Then you pull fuses and relays one at a time until the light goes out.
It could also be the alternator itself, so try disconnecting that.
A major short within the fuse box is also possible.
Accident damage areas are places to look for damaged insulation.
Do not start the vehicle, because a heavy short like that will quickly destroy the alternator.
Mar 12, 2011 | Mitsubishi Eclipse Spyder Cars & Trucks
Audi A4-how do i know if my alternator is bad or
START engine and turn on head lights to main beam if engine stops and battery is flat then the Alternator isent putting out 13.5 volts or 12volts so then turn off lights and turn on inn and with a test light check power lead on Alternator if you have power to alt then you have either Reg or brush problem .
Take it off and get it tested and if slightly faulty then get a change over one and refit start and recheck your head lights as they should come bright when engine runs evan at idle .
ITS that easy
Oct 14, 2009 | 2002 Audi A4
Draw on battery when car on
First disconnect the battery overnight just to make sure the battery is not self discharging......if it's dead or down in charge while disconnected....time for a new one.
Now.....if the battery is good....disconnect one battery cable and place a 12 volt test light between the cable and the battery post the cable had just been attached to. A bright light means a drain in the car.
Your job is to remove one fuse at a time until the light dims.
A dim light is OK...clock memory etc.
Remember....a open car door is a drain......the dome light.....so keep them closed while pulling fuses.
Also....if the fuses don't show a drain......disconnect ALL wires from the alternator....there could be a drain there.
Just keep disconnecting one thing at a time until the light goes out or dims.
Aug 12, 2009 | 2001 Volkswagen Jetta TDI
Battery goes flat in 2 days without use
its possiblly a diode in the alternator faulty.your best bet is to get an auto electrician
Jul 16, 2009 | 2002 Hyundai XG350
1995 Pathfinder 3.0L Electrical Issues
Unplug the ECM connection and see if those lights go off.For some reason the relays are not turning off and are controlled via the ECM.
Jul 07, 2009 | 1995 Nissan Pathfinder
Alternator has high voltage and not chargeing battery
Look if You start the car and wile car running idling, disconnect the positive terminal on the battery and the engine stops, You need a New Alternator, look on the fuse box on the engine compartment for a fuse or a Relay with the alternator name, the main fuse is bolted to the fuse box, but I doubt is a fuse
Jan 21, 2009 | 1997 Dodge Caravan
Charging & Starting Systems for Audi 80 Logo
83 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
