Question about LG Xenon GR500 Cell Phone
GR500 BOOT LOOP - LG Xenon GR500 Cell Phone
How to resolve constant boot loop in samsung galaxy fame
use usb connection from your phone and your computer to upgrade your phone's operation system from the samsung website
Jan 26, 2016 | Samsung Cell Phones
Stuck in boot up loop after factory reset,upgrading android then stuck in boot loop
If you have it reflashed with the custom ROM try to reflash it to official.
Jun 21, 2015 | Tablets & eReaders
Acer m5-581tg Auto repair loop WIndows 8?
it could be a problem with hard drive, try replacing it with a spare hd , if its still the same then maybe you could take out internal battery and put it back in ,even take out mem and put back in at same time of taking out internal battery ,it could help resolving the problems.
Mar 20, 2014 | Acer Computers & Internet
Boot loop
try pressing the power button and holding it for 10 seconds. Then wait a while. Turn it back on, you may press F12 or other key when the Samsung Logo appears (before Windows Logo) to see the boot options. Choose the one to check for any errors or anything else - Run diagnostics. Then also you may scan your hard drive for any failures.
Jun 04, 2013 | Samsung NF210-A02 Netbook
Sansa Clip Boot Loop
My Sandisk Sansa Clip + is not working, it's stuck on the Sansa logo, the Flower, Refreshing to the Media, Then, it turns back off and starts again, help me Please, Thank you.
Mar 03, 2013 | SanDisk Sansa Clip+
Transfer pictures from my LG GR500 to my computer
There is a super easy solution, if you are using windows  try using a live cd, which is a bootable cd. Here is the link to a good one: http://ftp.heanet.ie/pub/linuxmint.com/stable/8/LinuxMint-8.iso
just download and burn onto a disc using an iso burner (http://www.freeisoburner.com/)
then boot up the disk and plug in your phone, the os should recognize the phone as a mass storage device then you can retrieve your pictures as you would a usb
Mar 20, 2010 | LG Xenon GR500 Cell Phone
Front-Loading Automatic Washer is leaking water
if you have a wire loop in your hands
its more than likely the outside loop, the inside would still be looped on the boot between the door and tub
any way, if it is the outside lock loop it should have a spring connecting both ends
this loop goes around the door seal kinda behind a lip, if you inspect where the boot lips the panal youll see what i mean
the best way to put it back on
catch the top of the loop an the lip of the boot
keeping the rest of the loop as close to in postion as possible use two needle nose pliers to tretch the spring, you should be able to spread it far enough to slip the rest of the loop back into place
four hands are much better here I assure you
but it can be done alone, it just takes a lil paitence
and slow movements
hope this help
Oct 18, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
LG Xenon GR500 Cell Phone Logo
35 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
