Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Leaking oil at the base
My stand mixer is leaking oil around the base. The mixer may have been turned over during a move. What is the solution to this problem.
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Posted on Oct 31, 2008
Stand mixer leaking oil
Your gearbox grease is breaking down, time to repack it with some new stuff.
Nov 30, 2012 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenAid stand mixer is leaking oil. How do I
referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204176924.pdf
You can see that there are 5 screws holding the upper and lower gearcase together. They pinch the gasket number 26 together and prevent the oil and grease from leaking. Remove the chrome ring by prying gently around the ring. You will see the 5 screw heads. Tighten them and the leaking will stop.
If it still leaks then you may have to replace the fiber washers number 29 which will involve disassembling the lower gear case.
Mar 30, 2010 | KitchenAid KSM103 Professional 5 Series...
The mixer leaks oil around the shaft. Is this a user repairable problem? How do I find service centers?
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
If you still feel as though the mixer is in need of service, you may locate Kitchenaid certified repair centers through the following link: http://caservice.kitchenaid.com/
Jul 10, 2009 | KitchenAid K45SS Classic Stand Mixer
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Jul 09, 2009 | Food Mixers
Leaking oil
Jun 27, 2009 | KitchenAid Classic Stand Mixer
Oil leaking from shaft after wew moved it
Oil seal around the shaft probably dried up. Before replacing, try penetrating oil at seal, wait a day; if no better, replace seal.
Jun 25, 2009 | Hobart H600 Stand Mixer
My mixer is leaking oil. last time we made bread dough in it it sounded kind of rough. we figured wiyh the heavy load maybe that was the rteason for the noise. when we moved the mixer to clean it, there...
May 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid mixer is leaking from the part that spins?
I took mine apart and all the grease had settled down around the shaft in the housing due to lack of use,found no seal.Going to spread grease back up on gears,see what happens.I found this at KitcheAids web site.Good luck.
Dec 01, 2008 | Food Mixers
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
194 people viewed this question
Top KitchenAid Food Mixers Experts
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
