Question about Acer Computers & Internet
ASPI32 ROOT\LEGACY_ASPI32\0000 This device is not present, is not working properly, or does not have all its drivers installed.
paul7of9
  • 1189 Answers
SOURCE: Hello, hai right click "my computer"click
Hi, "click on this site; you may be able to download the Drivers you need" http://driversupdate.org/drivers-update-software.htm?msn=download%20drivers%20hp%20compaq%20presario%20c700t%20,%20pentium%20dual%20core%20mobile
Posted on Jun 20, 2010
  • 1739 Answers
SOURCE: My sound doesn't work. Everything is plugged in.
Hi betodria:
Try visitng this site and see if there are updated drivers available:
http://www.sharewareconnection.com/acer-drivers-update-utility.htm
Trust this helps. Please vote
Posted on Dec 24, 2010
  • 8909 Answers
SOURCE: I'm using Compaq Presario V3615
AS you state the "device is working properly" so it must be something else.
Try playing a music CD and if the music looks as if it is playing, it probably is and there is a mechanical problem with the headphone socket or the volume is not activated.
Check the Mixer Console by r/hand mouse click the loudspeaker icon and select Volume mixer.
Hope that fixes it
Posted on Dec 31, 2010
  • 11800 Answers
SOURCE: when startup it shows error fixed disk failure
The hard disk is near death - replace it and reinstall Windows using the recovery cd.
Posted on Apr 17, 2011
shademand
  • 114 Answers
SOURCE: This device is not present,
Please provide your Brand/Model of your computer and it's Operating System for example: I have a Dell XPS 8300 with Windows 7 Ultimate.
Please go to Start, then Programs, Accessories, System Tools, and System Information there you can obtain that information
Posted on Sep 08, 2011
What is root\legacy\hlnfd\000
it's a Microsoft system driver installed with Windows and should be located here:
C:\Windows\System32\drivers\npf.sysI
if you find it anywhere else it's malware and should be removed.
Oct 02, 2014 | Microsoft Computers & Internet
I need to download a driver for Pc camera logitech V-UAS 14, P/N: 861206-0000, PID: LN60786
http://www.logitech.com/en-us/support-downloads/downloads/webcams/legacy-devices/3378?section=downloads&bit=&osid=1
This the link for that camera model. click the downloads button to locate the proper driver for your Operating System.
Thankshttp://www.tech911.biz
Nov 15, 2011 | Logitech Webcam
The usb ports on my Fujitsu Siemens Amilio Li1718 are not working.......
First update the drivers, you can do this under device manager under contorl panel and maintenance & performance. You can also make sure the usb device is enabled and read properly. You can also download sotware lastly if needed.
Oct 01, 2009 | Computers & Internet
I am reformatting a Dell computer useing a Samsung HD160JJ/P hard drive The OS will not load because there is no driver present for the hard drive. I need to download and reinstall the drivers. Where can I...
When installing XP, you could always go into Bios and switch Sata to Legacy mode. That will allow you to install XP. Later you could try installing the SATA drivers, and switch the Bios back to ACH1 mode (or whatever it was called). I had no luck with the latter, as there is a bit of a 'Catch 22' as Device manager does not proffer that option when the drive is in Legacy mode. I gave up and now just run it in Legacy mode. In spite of what the manual says, you will find that eSata works fine in that mode.
Sep 14, 2009 | Dell Computers & Internet
No Audio
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Jun 28, 2009 | Intel Computers & Internet
PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
Nov 18, 2008 | Nikon CoolScan V ED Film Scanner
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
Computers & Internet Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
