Question about HP W2007 LCD Monitor
How to replace backlight in HP w2007 monitor
Backlight appears to be going dim. It's not as bright and brilliant as it used to be.
SOURCE: hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Posted on Mar 12, 2008
SOURCE: My hp w2007 monitor has no sound.
my hp w2007 monitor has no sound
Posted on Dec 04, 2008
skotkolr
  • 558 Answers
SOURCE: I have a HP w2007 20
1st check around the pedestal area on the back most of these are snapped on then you will find some screws to remove then use a knife or similar thin strong object to slide between the two half's of the shell and pry it apart it will pop are snap apart without much issue then you an get to work uncovering the power board and such the vga connection is removable with either a special nut driver or a pair of needle nose pliers turn the nuts and then also maybe the power connector as well then the board should come out and you can inspect for damage based on the damage you describe I bet you will need a new board E Bay will be your best bet at a store called Shop Jimmy, be careful if thescreen is cracked this is all pointless as you will get into some pricey repair to buy a new screen.
Hope this helps.
Posted on Mar 22, 2009
  • 732 Answers
SOURCE: HP w22 Monitor display disappears after about 2
bill, if monitor not covered by warranty, the check out YOUTUBE for long 8-12 minute video clips of LCD monitor disassembly or LCD monitor repair to find out what the major cause of your monitors SYMPTOM that you described above. Here is a small hint for you. If you didn't see the displayed data on the BLACK lcd panel with the flashlight "trick" then you would know that the entire "switch-mode-power-supply" was in complete SHUTDOWN mode or even blown the "line-in fuse" for the monitor. Also try a visit to www. ccl-la.com/badcaps.htm and view some of their vids on repair of lcd SMPS/INVERTER supplys and cold-cathode-fluorescent-lamp replacement. They also do the repairs and return shipping. Please rate this on fixya if this response was helpful. Bye for now. 12fixlouie
Posted on Oct 26, 2009
  • 732 Answers
SOURCE: How do you disassemble the hp pavilion f70 monitor?
plumldk1, Watch some video clips of "LCD monitor disassembly" at youtube. Yes, parting the rear cover from the front plastic bezel is the hardest thing to do!!!! Also visit www.ccl-la.com/badcaps.htm. You might see some tricks to help get the thing apart. Are you positively certain that it's the "backlight" and not the "electronic ballast" that has failed? Will you find any swollen electrolytic filter capacitors on the SMPS board? 12fixlouie
Posted on Jan 17, 2010
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
My laptop comes on but the monitor is blank
Your backlight is probably burnt out or the inverter needs replaced. The backlight will be a pain in the rear to do so you might want to try a new / used (working) inverter in it first. Hook your laptop up to a external desktop monitor. If you computer boots up, and you can see everything on the external display, you've got an inverter or backlight issue. Shine a flashlight on the laptop screen. You'll see a very dim image of your desktop.
Sep 09, 2012 | HP Pavilion dv4000 Notebook
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
May 20, 2010 | Toshiba Satellite 15" Flat Panel LCD...
HP compaq 6710b - Hi I can't adjust the brigthness of my screen from my keyboard anymore. I used to be able to hold down the "fn" key and then press "f9" to decrease or "f10"to increase the brightness. Now...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 30, 2009 | HP Compaq 6710b Notebook Pc
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Monitor keeps shutting off after a few seconds- hp dv4000notebook
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 09, 2009 | HP Pavilion dv4000 Notebook
Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
Can you explain in a bit more detail please...I don't know what you mean by.........
'when low down the brightness it work good'?
But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
Sep 04, 2009 | Dell InspironTM 1501 Notebook
HP Pavilion ze2000 Monitor is dim
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Aug 11, 2008 | Computers & Internet
HP L2000 Screen DIM
Might be the brightness. Check if there are is a key combination for adjusting brightness.
Apr 17, 2008 | HP Pavilion dv6000z Notebook
HP W2007 LCD Monitor Logo
83 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
