Question about Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP Mouse
Where is battery cover for targus amu51us? - Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP Mouse
2 Suggested Answers
  • 16 Answers
SOURCE: My mouse targus AMU51US can
http://www.targus.com/us/content.aspx?page=downloads
o find the Manual or Driver for your product:
  • Use the Site search at the top-right corner of the site.
  • Visit the product page by selecting your model from the list.
    (NOTE: You may need to select the "Archive" tab).
  • If available, select "Drivers & Downloads" in the black box beneath the price.
  • Go to the "Driver" tab and select the appropriate driver for your device.
    NOTE: If no downloads are available for your model, the "Downloads" link will be hidden on the product page
Posted on Mar 13, 2011
How to open targus amw2507us mouse
Hallo,
Under the mouse in the rear side it is a clamp what have to be pressed, and then the top cover will be off and can replace the battery
here it si a linke and a picture for it
512a5b26-0126-4353-a121-013d2bc0df22.jpg http://cdn.targus.com/web/us/downloads/pawm20u_ug.pdf
Sep 06, 2014 | Targus 2.4ghz Wireless Laptop Mouse With...
My mouse targus AMU51US can not work because i do not have a driver , because when i bought it,in the pakage is not included the driver,
Mar 13, 2011 | Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP...
How to install batteries in targus mouse
On the black cover, press on the Targus label - to release the latch - then slide the cover backwards. It's a little tight but the cover should come out. You'll need to (2) AAA batteries for replacement. Cheers
Jan 12, 2011 | Targus PAWM001U Mouse
I have model # PAWM004 & CANNOT LOCATE ON THE MOUSE WHERE THE BATTERY COVER IS? NEED TO CHANGE BATTERIES
On the black cover, press down on the Targus label - to release the latch underneath - then slide the cover backwards. It's a little tight but it shoud come out. I did it just a minute ago. You'll need two (2) AAA for replacement. Cheers.
Jan 08, 2011 | Targus PAWM001U Mouse
Put batteries into Targus amw1603eu mouse
The battery cover is the part of the top of the mouse on the opposite end from the scroll wheel. Turn the mouse upside down with the scroll wheel away from you. On the end closer to you is a latch (called a "hinge" in the user manual) for the battery cover. Depress the latch and slide the battery cover off of the end.
The user manual is at
TARGUS AMW1603EU User Manual
Dec 28, 2010 | Targus AMW05US Mouse
Cant click on anything..
If the red sensor that glows (on the bottom) is not on or flashing, you need new batteries. In that case, pry open the battery cover and replace. If it is on and it's not working. Try one of these things.
  1. Click the reset button on both, the mouse and the usb adapter.
  2. Making sure the device is installed properly, if not you might need a new mouse.
Hope this helped. Message me if it does or doesn't and I'll try to help more. (I have a Targus wireless mouse for my Toshiba laptop)
Good luck.
Jan 03, 2010 | Logitech Cordless Mouse
How do you get back off mouse to iunsert batteries
Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off.
If you need the user manual, follow this link to the download from Targus...
http://www.targus.com/us/downloads/AMW05_UG.pdf
Oct 31, 2009 | Targus AMW05US Mouse
Change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 07, 2009 | Targus PAWM001U Mouse
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Targus AMU51US 3BTN USB OPTICAL ACCSLAPTOP Mouse Logo
63 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
