I need to know how to change the password so I can pair a new device to the T325
SOURCE: bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
SOURCE: Bluetooth pairing
Before
you can use your headset, you must pair (bond) it with your phone.
Below are general Motorola headset pairing instructions to a mobile
phone:
Step A. Start Bluetooth on your phone.
Note: These steps are for most Motorola phones. See your phone's user guide for more details.
Step B. Ensure headset is in pairing mode.
Power
on the headset. The indicator light flashes to initiate easy pairing.
After a few moments, the indicator light will be steadily lit in blue
to indicate headset is in pairing mode.
Step C. Set your phone to find your headset.
Note: These steps are for most Motorola phones. See your phone's user's guide for more details.
If lost connection or stopped pairing delete blue tooth item and reinstall as above
SOURCE: trying to pair motorola n136 with my sprint rumors phone
Found this when trying to pair mine:
I had the same problem - what I thought was the unit number was not - it is actually HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/...
Basically, hold down the call button until it lights up (steady -not blinking), open the boom, and search for devices in your phone. When it finds it, the passkey is 0000.
