Question about DISH Network IR Remote Control
Dish tv 2 works but only very fuzzy on channel 56 dvr
My TV 2 remote was working fine until I pushed some wrong buttons and then it will only play 'the rat races' - I see it playing on the recordings but I cannot get it back to clear. I've tried many things, any advise much appreciated.
  • Official Brand Answer
  • 263 Answers
Ssmike1,
It sounds like you may have just switched off the channel to view satellite.
The channel for satellite is based on the connection you're using. If you're using a coax connection, it should be on channel 3/4 or 62. If you're using video cables like RCA/HDMI then you'll need to switch the input. On the upper left of the remote should be a TV/Input button. Make sure you're in TV mode and press that to see if picture returns.
If the problem continues let me know and I would be happy to try some additional steps!
Tommy Faust
DISH Social Media Representative
Posted on Feb 22, 2012
2 Suggested Answers
  • 374 Answers
SOURCE: Dish Network DVR not totally controlled from PC (Win Media Ctr)
Alfonso,
I do not know if you have received an answer to your post by other means but I know of no way that that is possible with the current configuration of the receivers Dish has out presently. You have already opted out of the slingbox option so that leaves me with one last suggestion which is that Dish is coming out with a new receiver SOON that will have the slingbox incorporated into it so that you connect it to your ethernet connection and you are in business. I will send you all info on the new receiver if you like.
Posted on Mar 04, 2009
I get the dish network screen on # 2 tv and have lost the remote I can't get # 1 tv remote to change the channel. Is there any way to program the remote for tv 1 to change the channel on tv 2.
smithgrvtn,
It is possible to get your TV1 remote to work TV2, but it would have to be a model 6.0/6.3/6.4. If it is not one of those models you would need to have a remote ordered and sent out; then it would work. If your remote is one of the above models; I have included the steps to get that done.
Changing Remote from UHF-to-IR and IR-to-UHF:
1.) Verify correct model of remote and it is IR/UHF compatible. Remove tab from bottom of remote. For TV1: Green Tab with Green 1 in it. For TV2: Blue tab with 2 and black UHF in it.
2.) Push correct tab into remote, and go to your main TV.
3.) Access System Information either with a remote, Sys Info button on front of receiver, or powering it off and pressing the up arrow.
4.) Press and hold the gray SAT button until all buttons on top light up. Release and while the light is blinking enter a number between 1-15 and press Pound(#)
5.) Press Record 3 times and check to see if the address changed to the number you chose. Verify remote works.
If you have any other questions you can let me know here; or at thomas.fuast@dishnetwork.com and I would be happy to see what else can be done!
Tommy Faust
DISH Network
Sep 05, 2011 | DISH Network DVR-625 DTV Receiver /...
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
DISH VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Jan 22, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Tip
I hope that helps.
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
DISH Network IR Remote Control Logo
143 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
