Canon PowerShot S230 / IXUS v³ Digital Camera
Problem for Canon PowerShot S230 / IXUS v³ Digital Camera
LCD screen shows weird colours
By Architek on Aug 16, 2006
The camera lcd screen on the back is displaying weird colours and distorted pictures. When a photo is taken the image is very weird in colours and horizontal lines when displayed on the CD (not matching what was shown in viewfinder when taken) and the photo itself on the computer is also distorted. Lens is OK.
Have checked all menu settings and butons, reset CF card, but still no luck
ANY IDEAS?
Cheers
David
Same Problem
Sep 19, 2008
-   When I try to take a picture, on the LCD disply there are horizontal lines and the image is white-gray. The camera is Canon PowerShot A75.-   evgsofia
Mar 07, 2008
-   I recently had the same problem with my z612 including horizontal lines on screen and very white images. I was able to fix the problem however it took 12 hours and a lot of frustration. The problem started when my 1 year old pulled the camera off the table onto hardwood floor. It had no apparent damage but took bad pictures. The problem was in the f-stop apeture and shutter. Both are made of small plastic flaps that open and close. A small disc with 6 slots rotates to move the 6 f-stop flaps. A solenoid actuates the 4 shutter flaps. If you shine a light into the lens and look in you will see that the shutter does not open/close properly or that the f-stop opening is no longer approx round. This happens when the plastic flaps fall out of position due to impact. This can be fixed but requires most of the camera to be disassembled to get to these delicate parts. It is very difficult to reassemble the lense assembly which includes the zoom lense, the image stabilizer, and the shutter assembly all of which ride on different cam tracks within two concentric plastic tubes. I do NOT recommend repairing this yourself unless you are crazy like me. Better off to buy a new one.
-   Guest
Feb 15, 2008
-   Distorted lines and unnatural colours on the lcd screen, same with image when photo is taken. I put the camera back to default settings, made no difference. Had a camera shop check the lense with laser and it is fine. Shop suggested sending it back to agent to have it reformated?-   Shakawe
Feb 10, 2008
-   Have the same problem with my Fuji S5000---bleeding lines of green yellow on the image --the LCD s and memory are fine because they show excellent images to previous photos and to the boot data.How do you replace the CCD ? Where does one get a new one ??-   Guest
Dec 25, 2007
-   I dropped mine on hard cement and when i brought the camera upon light i can see the distortion, like veritcal lines and its like half and half...i mean when i upload the pic to the computer you can see it but...when i turn it on and take pictures i can see distortions like blurry and stuff...i dont know what to do...i cant take back to the store i bought it cuz i lost my receipt and threw the box out...this sucks!-   vital_diaper
Best Solution
posted on Jan 03, 2007
Very Helpful)
Kilowatt
Rank: Apprentice
Rating: 100%, 1 votes
I had the same problem... black and pink horizontal "lines"...
I replaced the plastic PCB with the CCD-chip on it, from a friend who had also a F700 but the "lens-mechanic" was broken.
Since 31/12/06 I am again a happy man !!
Marc, from Belgium
Was this helpful?
Yes
No
Solution #2
posted on Jan 18, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Canon are replacing it free of charge, even if out of warranty
Solution #3
posted on Oct 08, 2006
Helpful)
ode2k
Rank: Apprentice
Rating: 92%, 2 votes
It may be related to the widespread CCD problems. Check this page out and see if it sounds like your issue.
http://www.imaging-resource.com/badccds....
Comments:
Oct 08, 2006
- You may be able to schedule a repair with Sony through this link. (Sony has taken over support / repairs for Konica / Minolta Cameras as of April 2006)
http://esupport.sony.com/US/perl/news-it...
Was this helpful?
Yes
No
Solution #4
posted on Jan 07, 2007
Helpful)
canonservice
Rank: Apprentice
Rating: 90%, 1 votes
check the FPC of LCD! may be some lines dameged on it.
Was this helpful?
Yes
No
Solution #5
posted on Feb 15, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sony has announced that this is a major defect in 8 cybershot models including the dsc-t1. Send it back to the retailers, they should fix it for free.
Solution #6
posted on Aug 20, 2006
Somewhat Helpful)
scrajmer
Rank: Wiz
Rating: 81%, 500 votes
its a case of damaged CCD. replace it and the problem will be solved.
Was this helpful?
Yes
No
Solution #7
posted on Mar 19, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Canon will fix this for free, regardless of the warranty situation.
Solution #8
posted on Jan 31, 2007
Somewhat Helpful)
scottinga
Rank: Apprentice
Rating: 97%, 12 votes
I WAS HAVING THE SAME PROBLEM BUT TOOK BATTERY OUT AND LEFT OUT FOR 3 DAYS. I put the battery back in and every thing is fine. The camera has a internal battery which maintains memory for 3 days while battery is not installed. Not sure really what cause the problem but seems to me what ever it was was being held in memory so once the memory was cleared do to no power every thing is fine .... gl I hope it works for you
Was this helpful?
Yes
No
Solution #9
posted on Feb 22, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Bin your camera and get a new one.
Solution #10
posted on Dec 30, 2007
Not Rated)
vincente
Rank: Apprentice
Rating: 0%, 0 votes
I got the same problem - When I take the picture and look at it later on the screen of the camera it's fine but when I upload it on my computer I get these really weird lines of different exposure. It's a laptop running on vista which is a new machine and never had the problem on my old computer.
Was this helpful?
Yes
No
Solution #11
posted on Nov 16, 2007
Not Rated)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 1999 votes
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Comments:
Was this helpful?
Yes
No
Solution #12
Not Rated)
t00nz
Comments:
Was this helpful?
Yes
No
Solution #13
posted on Jul 03, 2007
Not Rated)
Joe_Rex
Rank: Guru  Cameras & Camcorders  Expert
Rating: 86%, 237 votes
THERE IS A SETTING IN THE CAMERA FOR THAT DISTORTED VIEW YOUR SEEING IT LOOKS LIKE A PSYCODELIC POSTER... JUST CHANGE THE MODE TO NORMAL.
Was this helpful?
Yes
No
Solution #14
posted on Mar 23, 2007
Not Rated)
krayysee
Rank: Apprentice  Cameras & Camcorders  Expert
Rating: 78%, 5 votes
when i turned my camera on the screen was all white and sometimes it showed the horizontal lines on it..but i couldnt see any menus or pictures unless i loaded the on the computer. i had a friend open it up and he found a foam like piece that had fallen and caused a wire to short out. when he took the foam piece out, the camera was working fine again.
Was this helpful?
Yes
No
Solution #15
Not Rated)
sreekidu
Rating: 94%, 395 votes
hi ,
me too facing same problem, it will go to fully dead lcd after some time. i have given it for service,they told it is the problem with zoom and shutter. when they did wide and tele continuously it worked fine for some time..
Was this helpful?
Yes
No
Solution #16
Not Rated)
BLONDE54
Rating: 0%, 0 votes
I HAVE A COBRA DIGITAL 6415 CAMERA AND I CANNOT GET THE AUTO FLASH TO COME ON AND THE PICTURES ARE REAL GRAINEY AND DARK I DO NOT HAVE A INST BOOK TO GO BYE
Was this helpful?
Yes
No
Solution #17
posted on Aug 27, 2006
Not Rated)
newdawnfades
Rating: 0%, 0 votes
I have a powershot A70 camera too. My camera also displays the same symptoms as yours. Call canon on 1 (800) 828-4040 (US only) as it is a factory defect. Canon will repair/replace free of charge!
hope this helps
Comments:
Aug 27, 2006
- I did not relize you were australian, call canon on 13 13 83
or go to the website for more details: http://www.canon.com.au/
cheers
chris
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot S230 / IXUS
Questions and Unsolved Problems for Canon PowerShot S230 / IXUS
Do you recommend Canon PowerShot S230 / IXUS v³ Digital Camera?
Answer
Answer
once the camera is on, I cannot see an image thru the view finder, the screen is black. The battery... (More)
Answer
I'm experiencing the same problem. Brought the camera to a Ritz shop and they said it could cost... (More)
Answer
I have a Cannon Powershot S230. The mode selector slide is loose and slides back and forth without... (More)
Answer
after 50 pics asks something about folder but camera holds 500 pics what am i suppose to do? how do... (More)
Answer
I can't restore my pic...when i look at them on the camera there , there but when i take the memory... (More)
8 Other Users Have The Same Problem - Continued
Comment by cabl, posted on Dec 18, 2007
I think I have a similar problem. The lines on my camera are vertical and they get worse the longer I have the camera turned on- for more than a minute, until the lcd screen is almost impossible to see. I read the solution about replacing the CCD but I have no idea what that is and if I can do it.
Comment by Guest, posted on Dec 18, 2007
I think
Comment by longines, posted on Nov 08, 2007
Had one card replaced in China last year which fixewd the problem. Exactly one year later same problem - 256 colours
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot S230 / IXUS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
