Question about Garden
Want to remove gas tank from a 6hp OHC tecunseh engine.
    Sergeant:
  • 316 Answers
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. 11
Posted on Feb 21, 2012
I have a 6hp Tecumseh engine that want take the gas when it runing!
possible part blocked main jet or low fuel supply from blocked filter in the tank
May 10, 2016 | Tecumseh Garden
Govoner arm came off how to put it on in the right place
thats a honda engine
Search Results
Honda Engines ' GC190 Owner's Manual
engines.honda.com/parts/ownersmanuals/gc190 Download or purchase Honda Engine owners' manuals for the GC190.
Honda Engines ' GC190 4-Stroke Engine ' Features, Specs, and ...
engines.honda.com/models/model-detail/gc190 Official specs and features for the Honda GC190 OHC engine. ... is a small four-stroke gas engine designed for premium residential use. ... Owners Manual.
[PDF]honda 6hp gc190 repair manual.pdf
www.publicwalls.org/honda/honda-6hp-gc190-repair-manual.pdf
Apr 08, 2016 | Horizontal Engine 6 Hp Ohc Gc190mha2
Why does my honda hr214 sx lawn mower starts for 30 seconds then stalls
The fuel inlet tube is most likely clogged with fuel varnish or debris. Remover the carb bowl and slide a thin rod or paper clip up through tube and clean out fuel passage. Spray carb clean up through tube to complete cleaning. Repeat this at the end of the season and then remove gas from tank or use fuel stabilizer available at WalMart or any auto parts store.
Jun 17, 2014 | Husqvarna 160 CC Honda OHC Engine 21 in
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
How to remove gas tank from a 6hp Tecumseh OHC engine?
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~
Feb 15, 2012 | Garden
Honda gas powered lawn mower will not start
If it sat for years then its likely a fuel problem. Verify this by spraying a prime in the carb and trying to start it. If the unit starts then its a fuel problem. I would drain the tank and replace with fresh fuel, remove the carb and clean it.
Dec 30, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
