Question about Engines & Components for Nissan 200SX
IDLE ADJUSTMENT FOR 1999 NISSAN ALTIMA
WHAT IS THE PROPER IDLE ADJUSTMENT FOR THE 1999 NISSAN ALTIMA WITH A 2.4L ENGINE (IDLE R.P.M.)
ilragatzzo78
  • 241 Answers
SOURCE: Replacing a starter for a 1999 Altima
  1. Disconnect battery ground cable.
  2. Disconnect starter wiring from starter.
  3. Remove starter retaining bolts and the starter.
  4. Reverse procedure to install.
the bolts should be on the drivers side.
you will have to crawl underneath the car to do this task
Posted on May 15, 2008
SOURCE: engine dying
MY BACK LIGHTS DOENT TURN OFF WHEN I LOOSE THE BRAKE AND STAYS ON ALL THE TIME WHAT CAN CAUSE THIS
Posted on Jul 11, 2008
emissionwiz
  • 75822 Answers
SOURCE: nissan ga15 engine idle adjustment locations
The idle speed is computer controled, it is not adjustable, you most likely have sludge in the throttle valve and the idle speed control air bypass valve, clean them with carb spray with the engine running.
Posted on Sep 17, 2008
ZJLimited
  • 17970 Answers
SOURCE: How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
  1. Install or connect the following:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Posted on Apr 05, 2010
  • 4793 Answers
SOURCE: 1999 Altima: My 1999 Nissan altima is making a loud whining noi...
you call it the serpentine belt, we call it the fanbelt.it,needs tightening,slightly loosen the alternator, then pull away from engine and tighten belt, tight enough when you can move longest part of the belt, between pulleys, 1/2 inch in/out.
if squeel re occurs fit new belt.
Posted on May 07, 2010
Nissan altima SE 1999 2.4L my RPM it's always on 0.
ok so when its at o. do it run rough i think you should clean up your throttle body and your idle control valve the valve may be stuck and clean out your egr valve and the passage way in the pipe
Dec 12, 2015 | 1999 Nissan Altima
My 96 nissan altima dies at idle
Could be a dirty throttle body, vac leak, or a defective idle air control valve. The computer adjusts idle speed by controlling the amount of air entering the throttle body via the control valve.
Is the check engine light on ?
Dec 24, 2012 | 1996 Nissan Altima
I have a nissan altima 95 unstable idle.when u shift to reverse mode the engine stop
Unfortunately, this is a problem with a thing called the idle step control (I.S.C.) motor. To prevent having chokes like we used to in the old days, the engine automatically adjusts the idle depending on engine temperature/load conditions. The I S C motor is the component that does this.
Sometimes if the battery dies or if there is a lto of carbon nbuildup (from unburnt fuel), this isc motor goes out of alignement....you will have to take it to a mechainc where they will be able to rest the base idle settings and this adjustment as well.
May 30, 2011 | 1995 Nissan Altima
IDLE AIR CONTROL
I think there is a recall with idle speed in that year altima. check your dealership for recalls and idle adjustment. if it has high miles try spraying throttle cleaner into the throttle body. (spray it directly in throttle body not the mass air flow sensor on the air box) when its idling. worst case you'll need a new throttle body
May 03, 2011 | 2007 Nissan Altima 3.5 Sedan
I need to set the timing on my 2002 nissan altima
  • Tools needed: A timing light and wrenches.
  • Locate the crankshaft pulley at the front of the Altima's engine and clean it off to expose the timing marks. Start the car and turn off any accessories such as climate control, lights and the radio. Allow the engine to idle until it reaches normal operating temperature.
  • Turn off the engine and connect a tachometer to the distributor per the manufacturer's instructions. Connect the timing light to the battery and then to the number one ignition wire. Start the engine and verify it's idling at 1,000 RPM. Adjust the idle speed if necessary
  • Point the timing light at the crankshaft pulley to determine the amount of adjustment needed. Adjust the timing by loosening the distributor mounting bolts and turning the distributor until the crankshaft timing mark lines up with the middle line of the timing light.
  • Tighten the distributor mounting bolts and recheck the timing. Turn the Altima off and remove the tachometer and timing light. Reconnect the number one ignition wire.
  • Oct 07, 2010 | 2002 Nissan Altima
    May 07, 2010 | 1999 Nissan Altima
    How to replace starter on 1999 Nissan Altima
    You need to Replace starter or have battery checked for proper volts.
    Jun 16, 2009 | 1999 Nissan Altima
    Proper transmission level for 1999 Altima GXE sedan
    it should be when the car is a normal operating temperture and it should be at the top notch where it says hot he should hve roughly put 4 quarts in it.
    Dec 08, 2008 | 1999 Nissan Altima
    Engine dying
    Jul 11, 2008 | 1999 Nissan Altima
    Engines & Components for Nissan 200SX Logo
    183 people viewed this question
    Top Nissan Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Jim Y
    Jim Y
    Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
