Question about Kenmore 659 Electric Dryer
I have a kenmore dryer that runs fine but wont heat up. i have 120 vac on each leg of the heating coil
    President:
  • 2,468 Answers
Then the heating element has to be defective check it with an ohm meter
Posted on Feb 16, 2012
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 157 Answers
SOURCE: Dryer not producing heat
heater or stat
Posted on Dec 19, 2008
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Posted on Mar 08, 2009
  • 2699 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
Kenmore electric dryer #11066512694 no heat & keeps running
Heat circuit also runs through timer and motor
Oct 26, 2017 | Kenmore Dryers
I have a Kenmore Elite He3 dryer that runs on propane. The dryer worked fine until i ran the propane tank empty. When I filled the tank the dryer worked but did not heat up. I bleed the propane line...
To check the igniter ya need to use multimeter set to ac voltage and check for 120 vac coming into the igniter if ya have 120 volts ac and the igniter does not glow the igniter is the problem. This tip i wrote covers what to check when a gas dryer does not heat
http://www1.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 24, 2011 | Dryers
Will not shut off will not heat
check for 240 volts if its electrically heated,if you lose one leg of power or 120 volts on the timer side it wont turn the timer to shut off and only 120 volts wont operate the 240 volt heating element
Nov 16, 2010 | Kenmore 62602 Electric Dryer
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
No dryer or washer control will start the unit running. appears no power...we checked for 240v at plug it ok...
Check the 240 vac again, but measure each leg to neutral while attempting to start the appliance. Each "leg" should measure approx. 120 VAC< (half of the total voltage) and should not change when the unit is started.I think you will find that the two 120 VAC legs will read OK until start up. If the voltage value on one leg drops to 60 VAC or less and the other leg increases by the same amount, Then there is a problem with the neutral wire or the connection between the ground of your appliances and earth ground. This is very common, particularly manufactured homes. Most dryers, for example, use 240 VAC to run the heating element, but also use 120 VAC (one leg of the 240) to provide power to operate the control panel. So... every time a start is attempted, the line becomes unbalanced, the 120 VAC to the control panel suddenly drops, the control panel resets, removing the load, the 240 VAC line becomes balanced again and appears normal.
Jan 07, 2010 | Washing Machines
Drier has stoppd heating. Exposed heating element. Coils not glowing. notice that coil is for 240 v and we are in the USA, on 120 v system. Continuity test of coil causes light to only flicker.
You need the dryer supply voltage to be 240VAC for the heater. Everything else runs off one leg of that or 120VAC L1 (Black)-Neutral(White)-L2 (Red)
L1 to L2 = 240vac
L1 to Neutral=120vac
L2 to neutral = 120vac
Eric
Jun 29, 2009 | Kenmore 63942 Dryer
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Electrical how to make it to 120v.
The drive motors for the washer and dryer run off 120 VAC, but the heating circuits require 240 VAC in order to work. You will need to have a 240 VAC outlet installed in order for the appliance to run properly. There is no conversion for this. This is the way the appliance was made.
Oct 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 659 Electric Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
