Question about Philips Audio Players & Recorders
PHILLIPS GOGEAR CONNECT WON'T TURN ON - Philips Audio Players & Recorders
titi2cute
SOURCE: problem with my mp3player please help
Have you tried to reset it. If not, try to hold down the power button while pushing the volume button up. That helps alot.
Posted on Jun 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
anandg27
  • 1272 Answers
SOURCE: My Phillips GoGear Vibe won't
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • www.usasupport.philips.com - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
Posted on May 15, 2011
SOURCE: My Philips GoGear ViBE Digital Media Player
mine nether
Posted on Jun 12, 2011
  • 86 Answers
SOURCE: my phillips gogear vibe is
Hi winnie_th132,
You can find FAQ's, manuals, and software at the Philips Support Site:
www.philips.com/support
Just enter your model number in the search.
Here is the Overview page for the SA1VBE: http://ow.ly/5RIUN
I would recommend performing a Repair/Recovery which restores your player to factory settings, as well as updates the firmware. Below are instructions for performing a Repair.
If you have any additional questions or wish to speak to a Consumer Care agent, call 1-888-744-5477.
Hope this helps. If so, let me know by rating this solution!
REPAIR INSTRUCTIONS:
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
Posted on Aug 01, 2011
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
What video format does gogear vibe use?
my mp3/4 does not play video when you click on vidio it says video format not supported
Jun 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Need download phillips gogear 4gb software
i need downnload phillips gogear 4gb software to add hardware
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Problem with my mp3player please help
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips HDD120/05
Repair the GoGear - warning: this will delete all files from your player.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Feb 10, 2008 | Philips HDD120 MP3 Player
I turn on my Go Gear and it freezes
Get a firmware upgrade...whenver you reset the device it reset the firmware install..so get the firmware upgrade and that should solve the problem you are having..hope this solve the problem
Jan 27, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips 2GB mp3
Make sure you got the one with GoGear docking station instead of the one with Ipod Docking Station.
Here's how to fix the player:
Make sure you back up all songs on the GoGear before attempting this solution.
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 26, 2007 | Philips SA5125/37 MP3 Player
555 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
