Question about Nerf N-Strike Longstrike CS-6
Cocking bolt on Nerf n strike longstrike cs-6
I was battilng and pulled my cocking bolt and the was side fell off.
2 Suggested Answers
SOURCE: My kid opened the Nerf
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Posted on Dec 27, 2010
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
How do I unjam a double cocked nerf diatron
1. Make sure that there are two disks loaded in the launcher. They must be pressing against the pressure switch at the top of the chamber. 2. Use a screwdriver to push in the T-shaped switch that would normally be triggered when the priming lever is closed. When both switches are activated, the trigger should be unlocked, allowing you to fire and to release the priming lever.
Feb 15, 2013 | Toys
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Nerf N-Strike Longstrike CS-6 Logo
131 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Nerf Toy Expert? Answer questions, earn points and help others
