Question about Adcraft SG-813 Sandwich Maker
SG-813 Adcraft Panini Press: The top elements will heat but will not grill..
Ive tried greasing them. But I can not get them to grill, iIhave to turn the sandwiches over. Any suggestions
3 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: do you have a instruction manual for Adcraft
Hello there:
if you go to the manufactures web site for this appliance you should be able to download a copy of the manual . There may be a number that you will be able to call also for further assistance ok?
best regards mike
Posted on Jul 31, 2009
SOURCE: Adcraft panini grill top will not stay open.
i have the same trouble... i finally undid the screw that holds the cover, but not sure whether the spring is sprung or the clamp is loose..
What did you do, Kevin?
Posted on Nov 09, 2010
Converting a panini grill into a crepe hob. Removed top element, now bottom element draws to much on lowest setting. What can I put inline or parallel to negate the loss of the second element?
Big wattage resister or variable one till ya find what works as for size got to know wattage of removed element Maybe the answer
Jan 30, 2017 | Ovens
Uneven heating on grille, "Hot spots"
SORRY perhaps if you put in a MAKE then some one could assist .. we are not great at guessing .
Dec 19, 2017 | Adcraft Irons
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
The top piece is not heating up
If you feel confident opening the appliance (while disconnected from the mains of course!)
1. Check the internal cable between the bottom part of the unit and the top part. If this is damaged or tests to be open circuit, it will require replacing.
2. If the cable is OK, check the continuity on the heating element in the top half of the machine. If it is open circuit, then the element will require replacing.
Mar 25, 2010 | Adcraft 811E Sandwich Maker
Need replacement parts. Two bolts that secures the top plate to the rotation bar both broke (snapped) and I cannot remove the remains. Need new bar and bolts.
You will have to use a screw extractor to remove the broken off pieces that are still in the grill. You have to drill a hole into the remaining bolts and then tap or screw in the screw extractor. Turn counterclockwise and they will come out. Home Depot may have the allen head screws that hold down the bar.
Sep 04, 2009 | Adcraft SG-813
Do you have a instruction manual for Adcraft SG-811 Sandwich Maker?
Hello there:
best regards mike
Jul 31, 2009 | Adcraft SG-811 Sandwich Maker
Mar 05, 2009 | Adcraft 811E Sandwich Maker
Top Plates Do Not Stay Up As They Should
Follow Up From Postee: Determined that by simply removing the back cover (phillips Head Screw) that there is a brass clamp over the pivoting bar that has an alan head screw on either side. Simply tighten both sides and the lid will stay up. Done.
Feb 11, 2009 | Adcraft SG-813
Repair adcraft panini grill model sg-811E
There is a brass block with 2 allen bolts on the hinge bar. Tighten those screws.
Sep 07, 2008 | Adcraft 811E Sandwich Maker
Instruction Booklet Breville SG820XL Panini Press
I forgot how to reassemble the panini press coil /heater
Jun 04, 2008 | Breville 800GRXL
Adcraft SG-813 Sandwich Maker Logo
Top Adcraft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Adcraft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
