Question about Creative Labs PCWorks FourPointSurround Computer Speakers
When turn up or down volume a cracking sound coming up
  • rhartman01
    rhartman01 Feb 17, 2012
    The plugs or anything you mentioned are ok and plugged in the right way.
    I think that the potentiometer from the cabled remotecontrole is defective.
    In the early 70 and 80's there was a spraycan whit a kind of grafite that you spray in the potentiometer to make a better contact.
    So i think the to replace the potentiometer, but i don't lnow where to buy it.
    I hoped that someone on this forum know where i can purchase that potentiometer.
  • Brian Sullivan
    Brian Sullivan Feb 17, 2012
    there are many types of potentiometer on Ebayhttp://www.ebay.com.au/itm/Potentiometer...
    You might get these on Ebay im not sure which country you are in this might guide you to one
    you could get this on Ebay if you dont have an account you will need to create onehttps://scgi.ebay.com/ws/eBayISAPI.dll?R...
    Add Email adress
    Add Bank Acc
    Add Credit Card
    also add your postal adress
    also add a paypal account
    when you get to the paypal login page at the bottom you will see new to paypal sign up tab
    paypal to create an account
    paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adresshttp://www.paypal.com/
    be very specific when you type in the search
    always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
    you will even see the pictures of your item so you cant make a mistake and get them home delivered
    hope this helps you
  • Creative Labs Master
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Feb 17, 2012
My volume control knob cracks when I turn it up or down. How do I fix the cracking sound?
You did not post the make and mode but if this is an older audio system then the volume control is a film deposited variable resistor. They get dirty and need to be cleaned. You can get contact cleaner or wd-40 and spray the control to clean it. NOTE that you cannot spray it from the front, you must disassemble it enough to get to the point you can spray into the actual part from the back and possibly under it.
Jan 02, 2017 | Audio Players & Recorders
FIX A CRACKED IPHONE
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new
screen cracked you need to replace screen with another one by a sucker on the screen if will not suck do to the crack glue it on and slowly pull up the screen and remove the screen cables and the hidden cable for the screen (lift the black clip up carefully and pull out the screen in direction of the cable to come out. replace screen and put cables back on and clip cable back down.
Mar 15, 2013 | Apple iPhone4 4G iPhone 4
The internal speakers all of a sudden started to emit a crackling sound the problem is still there if i plug in headphones. how can i fix it?
sounds like the sound card board has a short. depending on the notebook, this may or not be replaceable. take it in and see if the board can be replaced
Jan 28, 2011 | HP Mini 1140NR Netbook
Behringer B215A replaced volume level knob does not respond.
You DON'T replace the board. If it is cracked, you bridge insulated wires around the cracks and epoxy them down.
Often the pads break from the traces near the pots. Look for a small crack between the pad of the pot and the circuit trace leaving it. Common problem.
Feb 09, 2010 | Behringer Eurolive B212A Speaker
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
We have a Denon AVR 1905/785 We cannot turn the volume down.... it is at -70 and full blast... the volume turns up and gets even louder.... but can't turn the surround sound down... help
if the volume control as been forced the conection in the switch as jammed +vol .this is usually a small preset under the knob the right hand one.pull the knob off pulling straight as not to bend spindle some time's the two presets are visable.a cotton bud dipped in spirits could solve your problem but some times you need to pull the top of the preset .it might need removing and replacing . this could be a more complicated problem caused by a variety of things here are a few,dry joints,cracked pannel .hope some of this helped . if in dire straits skype me farr64
Apr 27, 2009 | Denon AVR-1905 Receiver
No sound
the DVDS151 has its own built in volume control that is easy to hit the buttons near the bottom of the remote and accidently turn the volume down.
even tho your tv volume is set high it won't pass the sound to the tv if it is on mute or turned down.
Mar 18, 2008 | Daewoo DVDS151 DVD Player
Creative Labs PCWorks FourPointSurround Computer Speakers Logo
65 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
