Question about HP Photosmart M417 Digital Camera
Cuts on then back off
The camera was lent to someone who returned it claiming the batteries had died because the camera wouldn't turn on and the lens wouldn't retract (m407 model). I replaced the original rechargeable batteries with some rather pricey Kodak brand rechargeable batteries. The camera would then cut on but it would cut right back off and the lens doesn't budge from its erect position. I gave up and let it sit for a while. Tried it today and nothing at all when trying to turn it on. I put in brand new standard Energizer AAs and it would cut on, then back, with no change in the lens. Is something drawing power out of the batteries? Any suggestions would be very much appreciated being as its passed warranty and I lost the box it came in. Thanks.
  • Anonymous Apr 10, 2008
    THE PROBLEM I HAVE IS THAT WHEN I TURN ON THE CAMERA THE LIGHT STAYS LIT FOR ABOUT 5 SECONDS THEN TURNS OFF. WHEN I PUSH THE POWER BUTTON AND THE ARROW AT THE SAME TIME A BLUE SCREEN STAYS ON THAT HAS INFORMATION ABOUT THE CAMERA BUT I CANT SCROLL AT ALL. THIS SCREEN ONLY COMES
    ON SOMETIMES.
    Problem Solver:
  • 11 Answers
Definitely a dropped camera,
Try taking it apart and see if anything around the battery compartment is loose. It is pretty easy to take this camera apart... just make sure you don't have static charge on your fingers!!!
Posted on Apr 08, 2008
Sound like it was dropped and somone lied about it. Mine got dropped and it behaves in a similar fashon...something about a plastic pin that hold the parts of the telephoto lens together.I had a computer wonk guy lok at mine andit is the little pin on the bottom of the lens assembly inside the ring that snaps on and off. Mine would work if you help up on te bottom of the lens but the it stopped again...lotsa luck
Posted on Nov 15, 2006
Keep getting a "lens obstruction"
I recomend follow these step
1.- clean the side of lents circular side
2.- Turn OFF the camera and softly push the lents
3. Softly pull the lent while Turn ON the camera
I hope you resolve the problem
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | GE X5 Digital Camera
I was Importing some pictures to my computer from my Canon sd 1300 is powershot digital camera , When the Battery died , I was not in the room at the time , So I came back in and attempted to turn the...
Since your camera is new the priviledge of your warranty claims must not be lost. So do not tamper to lose this benefit but call up the call centre of Canon for registeration/advice. What you can do is to remove the battery and keep if off . Since the battery is now fully charged you can reset the battery after some hours. There must some error that could have happened when the transfer took place, even a possible errror in memory from your PC. Hope you try. Good day
Aug 13, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Lens wil not retract after battery died
It takes power for the Lens to retract. Recharge or replace batteries to get the lens to retract.
Jun 19, 2009 | Nikon Coolpix 5000 Digital Camera
Lens won't go back in
some times if the batteries get wet it will short the system and it won't turn back on... if you dropped it something may have shifted inside blocking the messaging systems inside the camera. i would take it to a local camera shop.
Jul 08, 2008 | Kodak EasyShare C663 Digital Camera
Lens cover error
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jun 17, 2008 | Nikon Coolpix S1 Digital Camera
My digital camera say lens error:21 how do i repiar the lens? sanyo vpc-e760 My SANYO VPC-S650 says lens error:507 everytime I turn the camera on. The lens has not returned back to normal position, and...
The lens has a servo fault. This can be either the lens motor, the helicoil in the lens is jamming, or the servo drive electronics has a fault.
You will have to send the camera for service if you want to fix this. I doubt you can fix this yourself unless you have access to the parts, and have the training and tools to do this type of service.
Jerry G.
May 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens problem
You have damaged lens barrel mech. Within the lens barrel, there are couple of tiny plastic gears and any damage to one of those gear will cause this kind of problem. I'm not sure it would be worth repairing the problem because of the cost of repair around $100. Good luck.
Mar 13, 2007 | Fuji FinePix A330 Digital Camera
Camera not turning on with new batteries
Return it to Vendor or Nikon for replacement
Sep 04, 2006 | Nikon Coolpix 4600 Digital Camera
HP Photosmart M417 Digital Camera Logo
74 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
