Question about Uniden DECT15885 58 GHz 1Line 1Line Phone
My phone says check tel line.
I just got the phones in the mail. i charged them over night. went to plug in the base and it said check phone line. i can't get them to work.
    Scholar:
  • 51 Answers
I have a similar model from the same manufacturer.
You've got the AC adapter plugged into the wall and the phone base, and the phone wire with std. phone connectors plugged into your phone jack and phone base, and it's still not working.
This can happen if the phone line is not active, or if the "pair" of wires is reversed (which is how DSL worked exclusively for years). Ultimately, it's not sensing a dial tone on the line you're base is plugged into.
First, make sure you can hook up a std. phone handset, if you have one, to the active phone line wire and plug to make sure the line and wire can result in a dial tone. Then, unplug that phone and plug in your new base. You should now be able to use the phone.
If, for any reason, you can't get a dial tone, it may be possible the plug you're using had a two-line phone plugged into it previously, which places the other line on another pair within the 4 wires for that type of plug. In other words, the active wires you want are in the wrong place for the phone to access.
I would recommend taking this handset to a phone jack you know to work fine with a single-line phone, near an AC outlet, and give it a try there like I outlined above. If it works there, then it's just the phone jack and maybe wiring position that is your issue.
You can also find at many hardware and electronic stores a simple phone line checker. It's a small box with some lights on it, with a short phone cable and plug coming out of the other end. You plug this into your phone line jack, and it tells you if the phone wires are wired correctly (typically a green light), or crossed (red light). This may be the source of your problem.
I hope this helps!
Posted on Feb 16, 2012
Getting check tel line message on base unit. Checked all the plugs on handsets, but still get message.
It could be one or more of these:
- the cord that goes from the base unit to the phone company wall jack is faulty
- the cord that goes from the base unit to the phone company wall jack is not connected or is not plugged in to the base unit jack labelled 'line'
- the wall jack is not active (ie; does not have phone company dial tone)
Sep 04, 2017 | Lands Phones
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Landline displays screen message Check Tel Line. Can't phone out or receive calls. Lights on the black box are out. I checked outlets, etc. E mail is weiner_@live.ca, land line 250-590-5196. Thank
I had to reboot our Shaw box three times last night before the phone started working again. Not sure what triggered the "check tel line" in the first place. My husband had just finished a phone call, I was going to make one right after him. The msg appeared as soon as he hung up. Interesting about your having a Uniden phone; it's the same brand as ours. This is the second time in a year that we've run into this problem. As for your old phone, is it analog? Reason I ask is, our rotary analog phone will work when the digital one doesn't.
Jan 05, 2013 | Lands Phones
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Dec 21, 2010 | Uniden Cordless Phone
I connected an elite 9035 to charge the handsets but also connect the phone line at the same time which i later realized was not as the instruction manual recommended. i am not able to make (no dialing...
Sep 15, 2010 | Uniden Cordless Phone
I bought a Uniden cordless phone, put the batteries in (it has 4 remote bases) and charged it for 20 hours as instructed. I tried calling it on my cell phone but I'm not getting s response. The display...
Double check that the telephone cord is firmly plugged into the back of the cordless phone base, the wall outlet, the outlet where the telephone modem is and at the L1/L2 jack on the back of the telephone modem. Your phone is not getting the dial tone line voltage from the telephone modem to the cordless base. There might be a short in the wiring. (It is unclear as to whether you are setting an old phone into this new base or swapping out and using another base with the old phone. Irregardless, the problem would seem to be not in the phone but ratther narrowed to the cord between phone modem and phone base. That is a very good reason to check how firmly the cord is plugged in.
Aug 27, 2017 | Lands Phones
All of the sudden the phone just stopped working. It says 'out of range'.
remove battery from handset then unplug base from power supply. Reinstall battery in handset then plug base back in to power.It worked for me.
Dec 16, 2007 | Uniden DCT756 Phone
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Uniden DECT15885 58 GHz 1Line 1Line Phone Logo
150 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
