Question about Intec Wii Induction Charger for Nintendo Wii
Wii remote charger blinks red fast
Red light blinks fast when a control is put on the charger.
When charging my contrllers the blue light on the charger base is blinking fast, is this normal
Everything is fine its when you start getting different light colors on the charger.
its blinking because its getting power so dont worry about it just make sure your controllers are on the base properly and you will be good to go.
Jun 11, 2011 | Nintendo Wii Remote Controller
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
I can't connect my controller to the wii console. Model number Rvl-001(USA). Model of nyko pistol accessory is Bn:090907 4632.My mom threw out the manual out by mistake.HELP!
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
May 13, 2011 | Video Game Consoles & Games
What does flashing red light on wii dock charging station mean??
Make sure that when charging the battery pack it must be attached to a wii-mote otherwise this may cause a flashing red light. If the battery pack is attached to the wii-mote and you still have a flashing red light this may indicate that there could a problem with the battery pack itself.
Mar 30, 2011 | Nyko Charge Station for Nintendo Wii
How do I synce wii remotes
instructions
  1. You will first need to make sure your Wii remotes have batteries. Then, turn on your Wii and go to the Wii menu.
  2. Open the little white door on the front of the Wii game console (this may require using your fingernail). You will notice a little rectangular red button.
  3. Open the battery compartment of your Wii controller, which may require removing the rubber jacket. You will notice a little round red button there.
  4. Press and hold the red button on the Wii game system and the red button on the Wii remote at the same time for at least 2 seconds. I usually hold down the remote button, then press the game console button for 2 seconds because it is easier for me. You will notice the 4 little blue lights on the front of the controller blink many times. The lights will eventually stop blinking and one of the four lights will remain on. The light that remains on tells which number Wii remote you have. The one on the left is number 1. The second from the left is number 2, etc.
If you bring your remotes to a friend's house to play, don't forget to sync your remotes back to your Wii console when you get home.
All the best!
Tsunami Dan
Read more: HERE
Mar 29, 2011 | Video Game Consoles & Games
My wii remote charger keeps blinking red while charging the remotes
@VentureForth
You're an idiot. The flashing red light is ON HIS CHARGER FOR HIS WIIMOTES. So why the hell would it be a sync issue with the wiimotes and the wii console? READ the WHOLE question before making yourself look stupid.
Aug 16, 2010 | Nyko Charge Station for Nintendo Wii
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
Wii Controllers not causing anything to happen.
OK so do led lights on the on the bottom of the controller just keep blinking or ever light up under "1" to signify that it is connected? What you do if they keep blinking is take off the battery cover on the remote and press the red button and the red button under the sd card cover at the same time. This syncs the wii remote with the console. You will need to do this with all new wii remotes.
Jan 11, 2010 | Nintendo Wii Console
Wii remote will not work
Ok, glad it now works for you. Please rate this as fixed so it does not show up in the unsolved problems list.
Many thanks,
Mowcius
Aug 02, 2008 | Nintendo Wii Console
Intec Wii Induction Charger for Nintendo Wii Logo
407 people viewed this question
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
