Question about Jenn-Air JXT8030ADS Kitchen Hood
MY jenn-air hood vent JXT8036ADS LIGHTS STAY ON EVERTHING ELSE WORKS
LIGHTS STAY ON ALL OTHER BUTTONS WORK. REPLACED CONTROL PANEL STILL HAVE SAME PROBLEM
    Welcome Back:
    Visited the website for 2 consecutive days.
Re Jenn air hood fan with lights that are stuck on. I replaced the tricl on the control board today as replacement control board is no longer available. Lights turn on and off! Thanks Michel for the tip!
Posted on Apr 16, 2018
    Habit-Forming:
    Welcome Back:
I fixed a JXT 8030 ADS that had the same problem. The lights are driven by a Triac located on a circuit board (SV158D) placed inside a plastic box (ref: AP4052900). This is not the '''control board'' with the switches. In my case the Triac was bad. To fix this you need minimum skills in domestic electricity and electronics mostly for desoldering, testing the triac and resoldering the original or soldering a new identical Triac in place. Also, you will have to secure the heat sink to the new triac and don't forget the thermal paste. The Triac will cost you about 2$. Enclosed is a few pictures, the triac is right beside the wiring that runs to the lights. Good Luck and be safety wise if you attempt this fix. Michel.
MY jenn-air hood vent JXT8036ADS LIGHTS STAY ON EV - p1010917-xzvfllqdgu0z021h5pfuakwa-2-0.jpg
p1010933-xzvfllqdgu0z021h5pfuakwa-2-2.jpg p1010933-xzvfllqdgu0z021h5pfuakwa-2-3.jpg
Posted on Aug 04, 2017
manhandy
  • 146 Answers
SOURCE: JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Posted on Jul 05, 2009
SOURCE: jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Posted on May 30, 2008
ndguy2481
  • 251 Answers
SOURCE: Control Panel Issue
sounds like a contorl board issue it might be going out i suggest get a repair guy out to fix it u can use our directory to find someone near u
Posted on Dec 03, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
SOURCE: jenn-air svd48600w
If your display has gone dimmer and dimmer or just gone out it is probably the display board. There are a few capacitors on the back of the board. There is one that is 68 Microfarad 35 Volts. It is common for this one to go bad. I replace it with a 68 Microfarad 50 Volt rated one and that usually solves the problem.
Posted on May 18, 2009
We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the st
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
Jan 30, 2015 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Unit has no power. Circuit breaker OK. Is there a fuse somewhere in the hood?
Very likely the power supply unit is faulty or the controller itself. The parts list shows no fuse internally. The power is directly going to the control board (item 3). Make sure you turn power to the rangehood off at circuit breaker before working on it.
JENN AIR Vent Hood Hood components complete Parts Model JXT5830ADS
Sep 06, 2014 | Jenn-Air JXT5830AD Kitchen Hood
Jenn-Air JXT8030ADS kitchen hood has stopped working
Although there was still power going to the hood, my husband decided to try flipping the breaker. This must have reset something in the fan as it is now working.
Jun 01, 2009 | Jenn-Air JXT8030ADS Kitchen Hood
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Control Panel Display
May be wiring ....at switch...reversed...polarity...or control replace..
Mar 22, 2008 | Jenn-Air JXT8136ADS Kitchen Hood
The lights dont turn off anymore
On line....sound control board to me...
Dec 29, 2007 | Jenn-Air JXT8136ADS Kitchen Hood
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Jenn-Air JXT8030ADS Kitchen Hood Logo
221 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
