Question about Sharp Office Equipment & Supplies
Factory Reset Sharp AR-M276 - Sharp Office Equipment & Supplies
5 Suggested Answers
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 37 Answers
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Posted on Mar 03, 2009
007tech
  • 95 Answers
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Posted on Mar 26, 2009
  • 32 Answers
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Posted on Apr 17, 2010
My Sharp AR-M276 is printing but all the pages are coming out black. What should I do?
Get the software program and/or driver at the device website make sure your computer is up to date and check you'r color or trycolor make sure it is not empty...
Feb 09, 2015 | Sharp Office Equipment & Supplies
How can i fix error L4-01 for Sharp AR-M276?
hi you should chek drive system and fusing. dv cartridge. drum unit rotations ...... if there's was normal change main motor.
Sep 29, 2014 | Sharp Office Equipment & Supplies
Afficharge u2-40 ar m276
I am guessing that you may have just replaced your toner cartridge. Remove the cartridge, switch the machine off and with the toner cartridge still out of the machine close the copiers front cover and turn the machine back on. This will reset the code and the machine should now ask you for the toner cartridge again. First of all give the cartridge a good shake and then refit it to the copier as normal. Hopefully your done, if not you may need to replace the cartridge and get a refund from your supplier as it may be faulty.
Good luck
Follow me on Twitter @CDOS_Service
Jan 12, 2014 | Sharp AR-5316 Advanced Digital Imager...
Ar-m276 u2-40 error
its bad comunication between the toner cartridge and developer so you need to replace the toner cartridge or the chip on the rear side of it
Mar 14, 2012 | Sharp AR-168S Copier
How to clear u2-40 error for sharp ar m276
This is error for Error in MCU-CRUM chip communication. Probably because of developer unit has bad contact.
Try to reconnect developing unit and then turn on the copier. If problem persist call service!
Hope that helps!
Sep 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
I got H4-00 problem in my AR -M276 Photocopy
Press # * C *, then enter 14 and press start, then 1 and start, then clear.
Jul 27, 2010 | Sharp AR-168S Copier
What is f2-04 at my sharp m276?
Possible problems:
1. Cartridge is not from this unit.
2. Cartridge is not for your region of delivery.
3. Defective chip in the cartridge
wrong sequence? try #*c* or
Mar 26, 2010 | Sharp AR-5316 Advanced Digital Imager...
548 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
